Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 29-12-2010, 11:43
Pättritsch Pättritsch is offline
Send a message via ICQ to Pättritsch
Default Jetta MK2 Modelcar built
Hey guys...
wasn't on here for a longer time...
Maybe you are interested... I'm not just working on my real Jetta... at the moment I'm building a modelcar of it based on the Golf MK2 G60 from OTTO models from france... it is a limited resin model (just 1500) but that's not interesting for me, because I want to have my own Jetta as model...
All you see here is absolutly selfmade by me
Base was something like this (but without ATS Cup wheels):
And that's my project:
I cut away the back of the golf and molded a completely new one... also I cut away the big bumpers to make a new frontend for the smaller ones.
At the moment I'm finishing the last details like the rear lights (will be clear in the end for sure) and I'm building a Rallye Frontend...
And to show you what I plan to do... this is my real Jetta:
I'm planning to make an kit of this model so anyone who is interested could buy one... available with small or big bumpers, with the Heckblende or not, with Rallye Frontend oder Jetta Frontend...
Also I could build a copy of your own Jetta if you like... feel free to contact me if you are interested...
Old 29-12-2010, 12:12
Christiaan's Avatar
Approaching the redline...
Wow
Cabby
Old 29-12-2010, 14:34
Marcski's Avatar
Marcski Marcski is offline
Wow
Old 29-12-2010, 14:44
perfect!!, i'm guessing you're gonna take a mold from the finished model.
Will you be offering the resin's as a kit or as a finished model? cause i might be interested in a kit depending on the price offcourse.
Old 29-12-2010, 15:04
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Very cool! How many hours did you put into it?
Old 29-12-2010, 15:06
Oudelut's Avatar
Oudelut Oudelut is offline
Are you a Boeddhist Munk by any chance?
Old 29-12-2010, 16:39
nice ...
Old 29-12-2010, 17:11
Very nice built (model as well as the real car)
Old 29-12-2010, 20:51
I will offer it as kit as well as completely built model... when I build it for you nearly everything is possible to rebuild your jetta
Don't know exactly how much it will be but I think the price for the resin kit will be between 150 € and 200 €
And some news for today:
Don't know how many hours I spent now... but this project took a lot of time... I began based on a MK1 Golf two years ago because there was nothing else at this time.
Then the MK2 came out and I started completely new.
Old 30-12-2010, 18:09
Some people really can do amazing things!
Awesome, man!
Old 30-12-2010, 19:38
Thank you man
Und weiter gehts...
Nearly finished... test paint
Old 30-12-2010, 19:49
Rick's Avatar
Rick Rick is offline
I wish I was that handy, man! Damn!
Old 30-12-2010, 20:17
Mitta's Avatar
Mitta Mitta is offline
Nice build! You've got skills
VWCulture.nl
Old 30-12-2010, 20:22
By the way, how did you make that new rear end? I see you first used clay to get the shape, but how did you go from clay to metal?
If you want, you can explain it to me in German, if that's easier. Just using English since it's the international forums.
Old 30-12-2010, 20:26
Vlammende Vlammende is offline
Send a message via MSN to Vlammende
Holy shit dude! That's awesome!
Old 30-12-2010, 20:35
Wenn ihr auch Deutsch versteht kann ich das auch gerne so machen
Also an dem Modell ist nichts aus Metall. Die Modelliermasse ist nur mit Aluminiumpulver eingefärbt. Das macht sie robuster und ich kann etwas besser damit arbeiten und die Konturen besser erkennen.
In Form gebracht hab ich das alles mit dem Dremel, nem Fräskopf, verschiedenen Schüsselfeilen und auch größeren Feilen und mein Lieblingswerkzeug sind diese Nagelfeilen (sind krumm wie eine Banane sind vom Naildesign)... damit lässt sich wunderbar arbeiten.
Und natürlich viel Schleifen und auch etwas Schnitzen
Ist schwierig zu erklären weil ich selber nie so wirklich weiß was ich da mache... ich fang an und dann wird das schon immer irgendwie auch wenn es anfangs nie danach aussieht
Old 30-12-2010, 22:48
That's cool, really would've thought it's made of metal.
Makes me want to try and do something similar. Be it only to find out it's harder than it looks and appreciate your work even more.
Old 30-12-2010, 23:51
VWJYI VWJYI is offline
welches resin wirst du denn gebrauchen für dein model? Das starre zerbrechliche oder das etwas biegsame? Die ferarbeitung ist mit dem biegsamen resin schon etwass einfacher. Du hast ja schon ganse arbeit geleistet mit deinem prototyp.
Old 30-12-2010, 23:55
Mitta's Avatar
Can you translate the German for me then because now i dont understand it
VWCulture.nl
Old 31-12-2010, 01:05
I can try... hope my English is ok...
"If you understand German, too I can also describe it this way.
At the whole model there is nothing made from metal. The clay is colored with some aluminium powder. It`s more strong then and I can see little dents and other things better.
I sculped it with the Dremel and several moldings some files and the banana files for naildesign... they work perfectly for me :P
Also I use normal sanding paper or carve some details out with a knife.
It`s difficoult to explain how I do that because most times I for myself don`t exactly know what I do there... it comes while I work on the model... at first nothing seems to look like it should. But somehow it gets like I want it to "
So now it`s in English :P
I use normal resin... the light yellow ore beige one... for some time I used resin mixxed up with aluminium powder to make it stronger...
But it`s quite flexible
