Go Back   Volksforum.com > International > Watercooled technical forums > General
Old 06-02-2005, 17:40
VWMAN's Avatar
VWMAN VWMAN is offline
Default what does "Gross Vehicle Weight" mean ?
i saw a 86 sciroccos vin number plate and says gross vehicle weight = 1320 kg? i cant belive it...86 scirocco is 1320 kg ???
Old 06-02-2005, 18:19
lwin's Avatar
lwin lwin is offline
i think a scirocco weights about 900 kg
Old 06-02-2005, 19:08
PerL's Avatar
PerL PerL is offline
The gross vehicle weight is the legal maximum weight for the car, including passengers and luggage.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 06-02-2005, 20:11
VWMAN's Avatar
Zul. Gesamteawicth, Gross Vehicle Weight, 1320 kg
Zul. Zuggewicth, Gross Comb. Weight, 2520 kg
What the plate says above.....
Old 06-02-2005, 20:28
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
The second line means in combination with a trailer
Passat B1 LS
Passat B8 Businessline R
Old 06-02-2005, 21:56
PerL's Avatar
Exactly, the total weight of both car and trailer.
Old 23-02-2005, 20:14
VWMAN's Avatar
according to the scirocco catalog 16v gtx's weight is 970 kg......
max speed = 208 km/h
0-80km acc. = 5.7 sec
0-100km acc. = 8.1 sec
Old 07-10-2011, 14:38
Teutonic_Tamer's Avatar
Teutonic_Tamer Teutonic_Tamer is offline
That would be just for the kerb weight - ie, the car as built at the factory, complete with all fluids (engine & transmission oils, coolant, screenwash fluid, and usually half a tank of fuel [though some may list this with just fumes in the tank]) and basic tools in the boot (spare wheel, jack, wheel brace) - but NOT including any driver, passengers or luggage.
Technically, the 'Gross Vehicle Weight' (GVW) will be the sum of the kerb weight plus the 'payload'.
And interestingly, the plated GVW will dictate the load index requirement of the vehicles tyres - to a legal minimum of 1.5, but often 1.75 multiplication factor of the GVW.
Sean - Independent Motor Vehicle Technician (ret'd)
07 Audi (quattro GmbH) B7 RS4 quattro sal (8EC) 4.2 FSI V8 32v (BNS) (with CSiC ceramic brakes),
07 VW Golf Mk5 GTI 5dr 2.0T FSI (BWA) DSG
