Go Back   Volksforum.com > International > Watercooled technical forums > Polo MK 1,2 and 3
Old 13-10-2010, 15:56
MolaR MolaR is offline
Default Change mechanical FuelPump Polo MK1/Audi 50
Hi guys,
can anyone tell me what should I do to change a fuel pump? Is there anything 'tricky' I should be aware like some kind of fluid that I must place in the gasket or the position I set the camshaft?
thanks
Old 13-10-2010, 16:05
J-9A-N's Avatar
J-9A-N J-9A-N is offline
Nope, nothing Tricky.
Old 13-10-2010, 16:17
And no fluid to correctly seal the gasket?
Thanks for the help again
Old 13-10-2010, 16:20
J-9A-N's Avatar
A new gasket should do the job. (Mostly included with the new fuelpump)
Or you can use some silicone gasket. (don't use to much)
Old 13-10-2010, 16:24
Thanks
Old 13-10-2010, 16:37
J-9A-N's Avatar
Good Luck!
Keep us posted if the thing is running.
Old 18-10-2010, 18:31
J-9A-N's Avatar
And is it running Molar?
Old 19-10-2010, 17:04
Not yet, the new fuel pump is working, but something wrong to the fuel tank (or the hose or in the fuel tank itself).
I installed the new pump and nothing... then I got a 5meter 0.6mm hose and connected to the pump and the other side to a tank outside, and the pump pulls the petrol.
(that's strange because you could suck some petrol from the hose, I thought that the pump was to weak, maybe the old pump was fine )
Today or tomorrow I will install a new contact set, it's the only thing that I haven't replaced in the ignition (that and the ignition, I've been crossing wires to start the engine, or try to )
Mola
