Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 02-06-2010, 02:10
Default 1552 introduces "double up"
Old 02-06-2010, 17:37
RubenD's Avatar
RubenD RubenD is offline
This was always has been my preferred option if you had to go from 4x100 to 5x100. I always wondered why nobody filled this hole in the market.
Would the price for the kit be the same for 256mm and 280mm rotors? Since there is a signification price difference in those 2 disks (not to mention standard el cheapo version or Brembo/EBC).
If anybody in the Netherlands need help, if can replace these for you (I can replace the wheelbearings if they are worn out).
Old 02-06-2010, 17:45
jettaracing's Avatar
449,52 dollar's........It's cheaper to redrill the original hub , and replace the bearing's........
If you want to go from 4x100 to 5x100 .
It will cost you 2 new bearings and someone to drill the new hole's in the hub.
Golf Mk3 Variant TDI 110pk
Golf variant Mk3 family car
The White Turbo Jetta!
Originally Posted by Misha
Old 02-06-2010, 22:05
joostvw's Avatar
joostvw joostvw is offline
If you find that "someone", he could fill the hole in the market too.
just give him the old hub and get a re-drilled back.
I don't know the English word for "ruildeel"
Scratch the surface!
-Golf 2 '841.9TDI
Old 21-06-2010, 15:34
Mu!s Mu!s is offline
a friend of mine has done this a long time agoo... I find the price just rediculous...... everyone could think of this?
Old 04-07-2010, 13:45
alpine alpine is offline
I made my rallye like that .
Old 04-07-2010, 13:58
maniacmark's Avatar
isnt it damaging the structural integrity?
Old 04-07-2010, 14:06
Roy 1.6's Avatar
Roy 1.6 Roy 1.6 is offline
Or just weld the old holes and then put the hub in the lathe. Then you've got a solid base.
"73 Käfer
Old 04-07-2010, 14:07
It's possible of course but i think that they are strong enough . I know a person driving 300hp mk2 4x4 with holdex with the same set up and he has no problems. Even after this crash there was no damages on the hubs http://lh3.ggpht.com/_5ORsDn-Eq00/S...ck/IMG_3280.jpg (the brake disk was broken).
