Go Back   Volksforum.com > International > Watercooled technical forums > Corrado and Scirocco
Old 25-05-2010, 21:33
vw_nutt vw_nutt is offline
Default ABF 2.0 16V in scirocco 2
Does anyone has experience or knowledge of mounting a 2.0 16v ABF engine in a scirocco 2. What needs to be changed and what can be reused when it comes to enginemounts driveshafts etc.
Old 26-05-2010, 09:09
Marcski's Avatar
Marcski Marcski is offline
what was the original engine?
if it was a 16v everything bolts up, 8v can use the same engine mounts but require a different exhaust header
which gearbox are you using?
Old 26-05-2010, 11:29
Now there is a 8v carb engine (90hp) sitting in. exhaust header has to be changed anyway since i want to fit a turbo on it. I want to try it out with the original 2.0 16v gearbox wich came with the engine, if it should fail i'm gonna look out for one out of a G60. And how about the lenghts of different type of driveshafts 16v, G60, TDI
thanks
Old 26-05-2010, 11:59
Marcski's Avatar
you need 100mm axles from a late cabriolet or scirocco 16v
02A has cable shift, hypro clutch and different mountingpoints, so all need to be customized.
use the search, a lot has been written on these subjects already
