Old 12-03-2010, 20:28
Der Ghopmeister's Avatar
Default VW Caddy 3.2 TD 4wd Bi-Moto ALM Racing
http://www.almracing.com/caddy.html
Engine's VW 1.6 TD x 2
Turbo : KKK K24
Diesel Pump : N/A Diesel (Bosch)
Injectors : OEM
Exhaust : 2,5" from turbo->3" from collector
Intercooler : UR-quattro 10vt
Airfilter : Open Type
Oil System : OEM
Transmission VW GTD 5-Speed x 2
Front Diff : OEM
Rear Diff : OEM / (Welded, 100%)
Clutch : Golf II 16V. Custom Hydraulic.
Custom gearshift handle, synchronized between front and rear gearbox.
Brakes & Suspension
Front Brakes : 280x28mm G60
Rear Brakes : 256x28mm 16V
Shocks : Golf II Lowering Shocks
Springs : Golf II Lowering Springs
Anti Rollbar : Golf II GTi Front+Rear
Powersteering : Golf II (custom)
Inside
Rollcage from Golf I, welded into rear subframe.
Recaro adjustable seats for street use.
Racing Belts 4pt
13" Steeringwheel
Custom Pedalbox
Gauges for trip/boost/oil etc.
Exterior
URquattro-style Fenders
Golf I RS Frontbumper
Custom Rearbumper
Corrado Headlights
Most of the parts will be in fiberglass. And pipe-frame for hold.
Old 16-03-2010, 17:43
bivw 16vg60 bivw 16vg60 is offline
dat gaat helemaal goedkomen bij alm
als je ziet wat ze met die 5 pitters doen pffff die jongens weten wel hoe het zit
veeel nedrglands gehebt......,wijnig gehielpt
T5 2.5tdi multivan lwb 335pk 678nm
Audi Rs2 94 nogaro blue 350pk+
Audi Rs2 95 nogaro blue total rebuild
Audi Rs4 02 B5 imola yellow 487pk
Project Rallye 2.5L 5cilinder turbo Sold
