Go Back   Volksforum.com > International > Technical > Turbo's, compressor's and NOS
Old 27-12-2009, 17:57
Hotrodvw's Avatar
Hotrodvw Hotrodvw is offline
Default Six seven Turbo Projekt
This is my draw thru set up I've been working on. 2007cc, T3/T4, all 2" plumbing, 38mm wastegate, etc... The pics should speak for themselves w/o much input from me:
port matched
chopped & ported
modified collector size
2"
I'll post more pics as I get it finished up...
Hose, Fittn's & Tube
Old 27-12-2009, 18:02
Roy 1.6's Avatar
Roy 1.6 Roy 1.6 is offline
Nice!
"73 Käfer
Old 27-12-2009, 18:06
impressive welding skills..
Old 27-12-2009, 18:10
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
Yeah, very nice. Are you going to run a decklid? Any cooling issues expected? (cooling fan drawing in hot air)
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 27-12-2009, 18:18
Hotrodvw's Avatar
A deck lid is planned.......not sure how well it's going to work out though. I've tried to tuck things in as best as possible though. I didn't do the tig, a buddy of mine did. He is very good!
Old 27-12-2009, 18:33
looks just sick
very well done...
Old 27-12-2009, 19:15
Domi
Old 27-12-2009, 19:17
Stijn's Avatar
Class of 2003
I'm lookin forward to reading up on your experiences. I've been looking to turbo my bug for a while, but I want it to be neat and tucked in under the lid. I've been trying to get the turbo below the original heat shield, but there's just too little room.
Connie: 16.
Connie: Mom!
Old 27-12-2009, 19:25
Hotrodvw's Avatar
Doing it all w/ a draw thru isn't easy, unless you're using small turbos This will most likely be stood off extensively. To me, not running a deck lid just screams " Too lazy to make it work."
Old 27-12-2009, 20:16
Stijn's Avatar
Class of 2003
Agreed. I'd like to run a simple setup with a small turbo. I'm not aiming for crazy power, just 'sparkly enough for daily traffic' fast
Connie: 16.
Connie: Mom!
Old 28-12-2009, 05:52
Hotrodvw's Avatar
Are you kidding? It's never enough......never!!!!!
More pics as of today. Got the carb hung finally, and a support bracket made (it will be re-done). I had to tap the manifold and install new studs for mounting, and also on the carb for the stacks. I didn't like the previous owner's set up for mounting. Now I can focus on the stupid little stuff.....
Old 28-12-2009, 11:13
VeeDubber's Avatar
Volksforum Crew - S2 Racer
I really love this set-up!
Draw-through has always had a vintage-feel to it which makes it perfect for Beetles!
By the looks of your pictures your planning this build carefully and are also keeping an eye on the build-quality. It looks like it's done by a pro! Is this your first turbo build or have you done some before?
Old 28-12-2009, 11:58
Zweiter's Avatar
Zweiter Zweiter is offline
aaaaaahhhhh, me likes!
Old 28-12-2009, 21:55
Hotrodvw's Avatar
Ha ha.....thanks. Nope, this is my first build. It's been slow going, but it's getting there. Now I'm up against the little time consuming crap, like throttle cable routing, wastegate mounting, build my oil lines, etc...
Old 18-01-2010, 06:53
Hotrodvw's Avatar
More pics........more progress!
Waste gate is mounted
New fuel line set up
And it's in!
Old 19-01-2010, 00:41
should have put it in the bigwheels jeep
Old 27-01-2010, 08:41
Hotrodvw's Avatar
Intake may get changed to swing it forward more.
Exhaust is coated, parts are going together.....
Old 27-01-2010, 12:16
VeeDubber's Avatar
It looks great in the car! Aren't you worried that you will experience a substantial turbo-lag because of the big turbo combined with the long plumbing?
Old 18-02-2010, 08:11
Hotrodvw's Avatar
What is it that you think is 'long'? It's no longer than most draw thru set ups.
Old 18-02-2010, 08:13
Hotrodvw's Avatar
Got the exhaust routed out of the car...
