Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk5
Old 13-12-2009, 18:01
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Default The MK5 VAGcom Thread
In this thread you can read all about mods which you can use to alter your MK5 Golf/Jetta. We assume that VAGcom is set up and working properly and that you are familiair with programming with VAGcom. We can not be held responsible for the information in this thread! Text based on VAGcom release 908
Always write up the original coding before you make any changes!!!
Auto-Lock
It locks all your doors once your vehicle reaches a speed of 15km/h, they stay locked untill you manually unlock them.
Walkthrough:
Module 46 - Central Convenience Module (for cars with powered windows, owners with manual windows select Module 35 - Central Locking)
-Select-
-Coding 07-
-Long Coding Helper-
-Check Byte 0, Bit 4-
-Exit Long Coding Helper-
-Do it-
If succesfull, VAGcom will display a pop-up that says: Coding Accepted
Auto-Unlock
It unlocks all doors once you retract your key from the ignition.
Walkthrough:
-Select-
-Coding 07-
-Check Byte 0, Bit 3-
-Do it-
Turnsignals as Parkinglights (US-Front)
Your turnsignals will be permanently on, it gives your car a US-look
Walkthrough:
Module 09 - Central Electronics Module
-Select-
-Coding 07-
-Check Byte 07, Bit 0-
-Do it-
Coming Home Function
Your headlights will stay on for another 30 seconds once you've closed your car. Please be aware of the fact that your light switch has to be in the ON position.
Walkthrough:
-Select-
-Coding 07-
-Check Byte 00, Bit 7-
-Do it-
Leaving Home Function
Your headlights will flip on for 30 seconds once you've (remotely) opened your car. Please be aware of the fact that your light switch has to be in the ON position
Walkthrough:
-Select-
-Coding 07-
-Check Byte 00, Bit 5-
-Do it-
Daytime Running Lights (DRL)
Your headlights will switch on once you turned the ignition
Walkthrough:
-Select-
-Coding 07-
-Check Byte 00, Bit 3-
-Do it-
More to come!
