Go Back   Volksforum.com > International > Aircooled technical forums > Type 1 (beetle '49->)
Old 17-11-2009, 23:24
brandijan brandijan is offline
Default Engine Help?? indenification
I can't tell what kind of motor, it was not in my bug.
number found under generator bracket
AES520018
I have pics on a piczo account under
http://myvw-bug.piczo.com/?cr=3
a couple of pics of motor and the number
Any help PLEASE, can't rebuild till I find out what it is..................
Old 17-02-2010, 18:45
schronce79 schronce79 is offline
Default this may help
Type 1
Code Year Engine/Notes
1- Pre-Jan., 1956 25hp/36hp
1- prefix indicates Type 1 and is not part of the sequential engine number.
2, 3, 4, 5, 6, 7, 8, 9 55-65 1200cc, 36hp/40hp
D0 1966/67 1200cc
F0 1966/67 1300cc
H0 1967 1500cc
F1 1967 40hp
E0 1967 M240 low compression 37hp
L0 1967 M240 low compression 40hp
H5 1968/69 1500cc
B6 1970 1600cc - dual relief, single port
AE 1971/72 1600cc - dual relief, dual port
AH 1973/74 1600cc - 8mm head studs with case savers
AJ 1975-1979 1600cc - fuel injected
Old 31-10-2013, 23:39
dustrat dustrat is offline
Default Engine Number
AES520018
This engine is a 1600cc twin port dual oil pressure release valve. I think you have misread the engine number , what you think is S is an 8 ie AE8520018
