Old 17-10-2009, 21:11
Default epic( doing it wrong turbo)
Epic Failures
Eric Hsu posted on March 15, 2009 11:45
Andy from Cosworth UK sent me a link to a thread on Scoobynet which is a UK Subaru forum. His email simply said, "omg-must-see-poor-workmanship. W T F ?" and a link to the thread. Normally Andy and I shoot the shit back and forth a bit about the happs with Subys in the UK or Time Attack stuff, but with the absence of the chit chat I knew this one had to be good. The Brits like to use the word "epic" so I titled this post in honor of my UK friends.
This one has got to be one of the dumbest fucking things I've seen. What is somebody like this even remotely thinking? You can go on the internet and figure out how to plumb turbos, wastegates, etc. easy enough.
This guy's in for a surprise when his interior catches fire.
This is the APC/Pep Boys DIY exhaust manifold.
I just know this one has to be some dumb ass forum SPE.
I knew somebody in this world had to try using a Flowmaster muffler as a plenum.
Somebody sent a a turbo to a fabricator and asked for a "custom MAF tube". Wrong side, eh?
While we're at it, I added this one from a "how to twin turbo your Mustang" "tech article" from some Mustang forum. I'm not sure if these examples are in the article as a joke or if they are actually up as actual examples. In this picture you can see the dude welded his stock exhaust manifolds shut and then proceeded to make a hole in the manifold and weld a press bent tube from Autozone that goes to the turbo. Maybe this guy posted the article back in 1989 on his BBS when there was less knowledge about turbocharging? I'm not sure what there is to be proud of. Check out the in depth 5 step article. It's a good read. Just make sure you aren't drinking anything because you'll blast your screen when you crack up.
Old 17-10-2009, 21:33
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Passat B1 LS
Passat B8 Businessline R
Old 17-10-2009, 21:36
GerardMkIIVR6's Avatar
Ongelooflijk sommige mensen DAMN.
En deze gasten lassen volgens mij met de fles dicht
Built NOT Fucking Bought
Old 17-10-2009, 21:50
Marco's Avatar
niet eens met een fles, volgens mij gewoon met elektrode....
Passat B1 LS
Old 17-10-2009, 22:04
Volgens mij met bak en braad vet want het spettert nogal wat
Old 17-10-2009, 22:36
sander_beer's Avatar
sander_beer sander_beer is offline
en dan dacht ik dat ik niet goed kon lassen
Old 17-10-2009, 22:38
jettaracing's Avatar
Die turbo met die opgelaste schoepen ,geweldig !!!!!
Golf Mk3 Variant TDI 110pk
Golf variant Mk3 family car
The White Turbo Jetta!
Originally Posted by Misha
Old 17-10-2009, 22:49
JarnoVWPolo6N JarnoVWPolo6N is offline
Een dag niet gelachen is een dag niet geleegd, en ik heb zojuist genoeg gelachen voor de komende 2 maanden man man, hoe erg kun je de klok horen luiden maar niet weten waar de klepel hangt
Old 17-10-2009, 22:57
OakgreenVR6's Avatar
OMG!
Dit moet ik maandag aan m'n collega's laten zien, altijd leuk om andermans 'hobbywerk' te zien.
1990 Golf mkII GTI 3.0 VR6
Proud owner, since '97
Old 18-10-2009, 07:30
Die buizen lijken wel aan elkaar gerot ofzo. En die turbo met die extra schoepen er op is inderdaad geniaal! Vooral door dat kleine puntlasje.
Jarno, een dag niet gelachen is een dag niet geleefd. Legen doe je op de plee. Nog zo'n voorbeeld van de klepel horen vallen maar door de bomen de klok niet meer kunnen zien.
Old 18-10-2009, 08:56
Domi
Leuke manier van stoelverwarming Hoe sneller je rijdt hoe warmer het wordt
Old 18-10-2009, 09:14
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Originally Posted by OakgreenVR6
OMG!
En dan de eerste 5 minuten met een stalen gezicht volhouden dat dit van je eigen VR6T is. Ik zou die gezichten wel eens willen zien
Old 18-10-2009, 10:54
maar 1 woord voor: WHAHAHAHAHHAHAHAHHAHAHHAHAHA
Old 18-10-2009, 13:01
tering beun de beunhaas. hahahahahaha
Old 18-10-2009, 13:36
Marniks's Avatar
Marniks Marniks is offline
hahaha jezus ik dacht dat ik een beunhaas was
Two Stroke Zombies
Old 18-10-2009, 15:16
cloontje's Avatar
cloontje cloontje is offline
och ja , een blinde was blij als hij zo kom lassen.
Gr
golf 1 gti '77 under construction
Passat dsl '80 130 PK TDI
Passat station 2004 130 PK TDI
Old 18-10-2009, 16:06
De Limburger's Avatar
Jongens even serieus he: Zo ben ik anders ook een turbo setup aan het bedenken, maar dacht eerder aan een 1.8 8v met een astmapompje of een haardroger, aangezien ook ik niet kan lassen, dan ziet het er altijd nog beter uit als dit bak en braad van CROMA..
Gr Ronnie
Old 18-10-2009, 22:41
Gertjan's Avatar
Gertjan Gertjan is offline
Epic
Old 19-10-2009, 06:01
Tomvw Tomvw is offline
OakgreenVR6
Hahaha te laat ik heb ik het al gezien
Ik zou vooral benieuwd zijn naar de werking en hun gezichten als ze daar nou een filmpje van hadden.
Vooral die met dat turbine-rotor en flexible spruitstuk
Kever 1959
Old 19-10-2009, 11:52
dit is in elk geval wel iemand die kan lassen
