Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 29-01-2009, 16:53
garoothos garoothos is offline
Default Help mk2 golf gtd glow plug problems
Hi i have 2 1991 golf gtd's both with a similar problem
1st one, The glow plug control unit was broken and had been bypassed with a switch, i fitted a need glow plug control unit and now the glow plugs come on when the ignition is switched on but they dont turn off and cause the battery to run flat.
2nd one, there is no power getting to the glow plugs when the ignition is turned on, i have swapped over the control unit and tried a known good relay also swapped the temperature sensor on the coolant flange next to the coolant temperature sensor with no sucess there is power getting to the control unit but not coming out of it.
Can anyone help?
Thanks
Gareth
Old 03-03-2009, 18:43
Sneakybass's Avatar
Sneakybass Sneakybass is offline
the relay that was suposed to turn off the glow plugs is dead. you nead to replace that one, and cause of the glow plugs didn't turn off, your glow plugs are melt up. cause the tempature was too high after more than 10sec. of glowing.
Old 12-09-2009, 22:35
le polo le polo is offline
Sneakybass ; "the relay that was suposed to turn off the glow plugs " is diferent from "the relay that was suposed to turn on the glow plugs " ???
