Go Back   Volksforum.com > International > Watercooled technical forums > Passat, Santana, Quantum Passat CC
Old 27-09-2004, 16:18
Ebut's Avatar
Ebut Ebut is offline
Default Red steelies and white walls
Posted my 32 B in the dutch section, but thought you guys might want to see it too.
After a hard weeks work, I'v finally got em done. Hope you like em as much as I do.
VW-Speed.nl
Old 27-09-2004, 21:30
FDL FDL is offline
Well, it's a little bit weird but what matters is that you like it....
I would do like this one:
Old 28-09-2004, 11:16
Ve_Erre's Avatar
Ve_Erre Ve_Erre is offline
Send a message via MSN to Ve_Erre
I don't like both...
You paint even the pressure valve...You didn't disassemble the wheel and tires to paint ?
And about the paint in the side of tire...The composition of the paint Doesn't reacts with rubber on the sidewall ?
If you like...no problem...
VOLKSPAGE.NET
Old 28-09-2004, 12:47
Ebut's Avatar
I did take the wheels of the car to paint them. The paint hasn`t reacted with the rubber so far, its still on there and the tires look fine, so no problem I guess...
VW-Speed.nl
Old 28-09-2004, 16:01
Ve_Erre's Avatar
I don't the wheels and tires but I like the car...
VOLKSPAGE.NET
PerL's Avatar
PerL PerL is offline
Well, it sure is different, but I wouldnt do that to my Audi, that's for sure.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 28-09-2004, 16:43
Volkswouter's Avatar
In my opinion this kind of wheels belong to hodrods or either black cars.
I said in the dutch forums that i don`t like the contrast.The wheels are about the same color as the car.
http://www.volkswouter.nl
Old 29-09-2004, 19:40
Putzgrila's Avatar
Putzgrila Putzgrila is offline
Doubtful esthetics
What interests is the owner like!
