Old 17-01-2009, 21:18
sidecarphil's Avatar
sidecarphil sidecarphil is offline
Send a message via MSN to sidecarphil
Default my MK2 ED1
hi there and welcome
i'm an english guy living over here near Groningen with my dutch girlfriend
sorry it is in english but my dutch is not this good yet LOL
it was bought as i needed a car for winter as i only had my ZXR750L1
but i changed my mind as i liked it so much
so here we go , this is the day i picked it up
it was seen on marktplaats , listed as good general condition but oil light coming on
these are the pictures i took the day we looked at it
Old 17-01-2009, 21:23
then i got it home and gave it a dam good clean up and service
The oil light was coming on when the engine was hot , and more when i was cornering
so i changed the oil and filter with a genuine filter and good quality 10w40 oil
and i also saw this
so i removed the sump and with a few tap's with a LARGE hammer and we were sorted
Old 17-01-2009, 21:26
then the clutch went
so i changed it with an LUK item , changed the oil again as it was really bad
i fitted the weighted arm from a MK3 and all new bushes and links
BUT THEN
disaster hit ,
the earth wire to the gearbox had snapped inside the shrouding
this then fried the ECU , but it took me about a week to find this
thanks to every one on here who helped me with this problem .
a new one was sourced from the USA as my car has a lambda probe
fitted and we were off again
i also fitted some new front tyres as they were getting low
but i have had a wheel wobble ever since i have owned the car , but i've not been able to trace it as of yet
Old 17-01-2009, 21:28
Welcome !
Nice ED1.
Golf2 gti vr6 edition blue
Golf2 gti 20vt edition blue
Golf6 gti R
well i've sort of got out of sync with all the work i've done so here is what i've got up too
changed the rear light's to red/clear with supercharged Range Rover indicator bulbs (blue but flash orange)
fitted the black/red ones to the Mrs' 1.3
then i changed all the front lights to crystal ones and matching indicators ,and made an uprated wiring loom with 2relay's( this will be transfered to the Mrs' little 1.3 when i upgrade to HID)
the indicators were fitted with supercharged Range Rover indicator bulbs (i love these , better than silvertec poop)
Old 17-01-2009, 21:29
Welcome !
thank you
Nice ED1.
it will be
Old 17-01-2009, 21:30
have you tried putting the rears on the front? (concerning the wheel wobble)
Old 17-01-2009, 21:31
happy motoring for a couple of months
then disaster again
when the car got warm it was stuttering coughing and was soo rich
i was down to 200 km per tank of fuel
so changed the blue cooling sensor , airflow meter , coil , lead's, dissy cap , rotor arm , ign amplifier
but still nothing sorted
so i started proper diagnosis with a multimeter and all
i stupidly left the ECU to the last as it was new !!!!!
but it turned out the plastic cover above it had a nice little crack in it letting water drip onto the connector !!
green wires , so i stripped the connector cleaned every pin , and refitted with a fixed cover
but the problem was still there i little bit
i had a 4 branch manifold to fit with a new (quieter) exhaust as the one on the car was a single box LOUD one !!
as i was fitting the 4 branch i noticed the lambda probe was rattling
problem found , new lambda fitted and oooooh yeah we off again
but i have now got problems with the backbox rattling on the rear beam
it appears the back box is for a 16v modded to fit the rest of the system (not well)
so i think i will upgrade to a stainless system from a 16v as i love the look of the 2 square tailpipes
Old 17-01-2009, 21:33
well we went to the nurburgring over a weekend in november as i was visiting a friend in a german hospital after a serious sidecar racing crash which lead to the death of my good friend Steve Norbury R.I.P mate
but this uncovered a few problems with the brakes ................... they are poop
Old 17-01-2009, 21:34
just a couple of nice pictures i have taken in the winter
Old 17-01-2009, 21:35
well after the trip to the nurburgring i decided to upgrade the brakes and after a little bit of digging and reading on here i decided that i would buy some 280mm G60 front brakes (bedankt Alberto)
old poop little 239mm ones (will be fitted to the Mrs' 1.3)
shiney new G60 280mm front set up with painted calipers
old V new
i had a problem fitting these as the left drive shaft was stuck in the hub
so i removed it and pressed it out , as i was at work and had all i needed
this also lead me to find the problem with the wheel wobble
the inner joint's grease was like tar and it didn't move nicely if at all so i stripped it claened it and added some new grease , wobble gone PHEW
painted the rear calipers too
i checked before i fitted it all that the wheels would clear the calipers but i didn't realise how close it was till i saw this
but they look cool behind the wheels
i just need a 22mm master cylinder as the peddle seems to move a long way now
brakes are fantastic though
Old 17-01-2009, 22:19
Madison's Avatar
Madison Madison is offline
Nice E.O.
Old 17-01-2009, 22:32
Emiel's Avatar
Emiel Emiel is offline
I'm sorry for your buddy, nice car anyhow!
Skoda Superb 2022
Fiat 500C
Old 17-01-2009, 22:37
next on the list
suspension then VR6 conversion
BUT it is a 1989 car so i understand it is harder
Old 18-01-2009, 13:55
Smitje Smitje is offline
Cars looking good. Are you going for coilovers or a shock/spring set up?
Old 18-01-2009, 15:13
tim_j's Avatar
tim_j tim_j is offline
this car wil be mint, keep up the good work
Old 18-01-2009, 18:22
i cant decide on suspension at the moment
budget wont alloy a 1000 euro coilovers
but i would love a set , i have heard bad things about the hottuning ones
but i think for 200 euro i cant go wrong
wheels will be the lenso BSX 16" but i will wait till i have decided on engine/ gearbox / 5 stud hub's
dont want to buy wheels for my 4 stud only to have to buy some more wheels if i use VR6 hubs and brakes
Old 18-01-2009, 19:01
Fabian_GTI's Avatar
Fabian_GTI Fabian_GTI is offline
Send a message via MSN to Fabian_GTI
Seems like a bit of a problemcar, it also seems to be in good hands!
Goodluck with it.
Greetings
Old 18-01-2009, 19:27
hey fabian
you have a 20v ??
is it turbo one ??
did you do the conversion yourself ??
info please
Old 18-01-2009, 21:46
tim_j's Avatar
Goodluck with it.
Greetings
what can you expect.... mark 2's have an avarage of 20 years old..
