Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk1
Old 16-09-2004, 00:47
Default Nissan powered mk1
Stats:
Engine: JDM Nissan SR20DET
4 Cylinder 1998cc Displacement
Turbocharged and Intercooled
Modifications
Nissan Sentra SE-R FWD Transmission with Viscous LSD
G.E.T. Custom Engine and Transmission Mounts
G.E.T Custom Downpipe
G.E.T Custom Intake using a HKS Super Mega Flow Filter.
Custom VW/Nissan Hybrid Axels.
Turbo XS RFL BOV
Nissan GTiR Intercooler underhood mount with 2.5 Inch Plumbing and custom ducting.
APEX'i SAFC
3" Downpipe, 3" Custom Exhaust Piping
JDM NA S13 HKS Hiper Muffler
SPEC Stage III Clutch Kit
Chassis: Volkswagen Rabbit Mk 1
Front Engine-Front Wheel Drive
Front Wheel Disc Brakes, Rear Drum Brakes
5 Speed Manual Transmission
Modifications
VW Mk II Steering Knuckles and Spindles.
90-92 VW Round Light Front Grille Conversion
Tokico Illumina Adjustable Struts
Neuspeed Adjustable Perch Coilover Springs
Unidentified Front and Rear Sway Bar Upgrades
Neuspeed Front Strut Bar.
Unidentified Lower Front Brace and Rear Strut Bar.
Unidentified Adjustable Camber Plates.
G.E.T Custom Adjustable Tie Rod Ends
Momo Lakes Driver's Seat.
Momo 4-Point Harness, Steering Wheel and Phantom Shift Knob.
Gutted Interior.
found here:
http://www.epikmotorsports.com....html
Old 16-09-2004, 16:40
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Hmmm, nice !!
Passat B1 LS
Passat B8 Businessline R
Old 16-09-2004, 18:36
Volkswouter's Avatar
And freakin reliable...
http://www.volkswouter.nl
Old 16-09-2004, 19:46
Volkswagenaar's Avatar
International Section?!
k00l, I like it!
Nice project
Old 16-09-2004, 20:31
don`t like a nissan engine
Old 17-09-2004, 16:12
bobby-digital's Avatar
there is allso a mk1 with a rear honda NSX engine, anyway nissan engines suck bigtime they brake down when you take a look at it
Old 24-09-2004, 22:26
songie songie is offline
great nissan engine , can output 400 HP in stock configuration with a bigger turbo , 700-800 HP with a modified one ....
just why do you put it in a volkswagen ? doesnt VW produce any good engines to use ?
i mean , i love a nice project and it certainly took quite the effort .... but come on , it doesnt belong there
you dont see me putting a VW engine in my S13
anyhow nicely done though , just buy a nissan if you want it that bad
Old 25-09-2004, 11:12
Marco's Avatar
There is/was also an Golf mk2 with an opel 16v engine in it. Maybe someone has a picture of it.
Passat B1 LS
Old 01-10-2004, 13:51
Tjeerd's Avatar
Tjeerd Tjeerd is offline
NIce job, but but its a Nissan, to bad they didn't use an engine from the VAG!
Old 22-01-2005, 15:44
cobble cobble is offline
may be they used a nissan engine for the reaction found hear?!
Old 22-01-2005, 15:56
RedJet's Avatar
RedJet RedJet is offline
The mk2 grill doesn't fit properly. Look at the gaps in the upper corners.
Old 31-01-2005, 14:01
Housey's Avatar
Housey Housey is offline
Send a message via MSN to Housey
This is what that comes into my mind when i first saw this "WHY?"
Old 10-02-2005, 12:57
The Walrus The Walrus is offline
Is it just me or is that drive shaft very very short ? I trust they have a ltd slip diff or the inside wheel just spins its life away ?
Old 10-02-2005, 15:01
Big_Mac_Mark's Avatar
SICK! But why?
- Golf MK4 2.0, 1999
