Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk1
Old 01-07-2008, 13:46
cola76's Avatar
cola76 cola76 is offline
Default upgrading brakes
does anyone have experience with modification mk1 239mm discs on 256mm discs...i bought front brakes from polo gti 6n2 lucas calipers and the adapter is different...space between two bolts that holds calliper is wider,so i would like to ask if anyone have ideas for this kind of upgrade...which adapters fits (which car-audi models or some others vw-s)...Greetings from Croatia!
Old 01-07-2008, 14:30
Marcski's Avatar
Marcski Marcski is offline
one topic is enough
source scirocco mk2 16v spindles and brakes, they had 256 mm brakes and are a direct fit on a golf mk1
Old 02-07-2008, 08:26
cola76's Avatar
that's the main problem...i've allready try to find rocco's brakes...but the pursuit was not successfully...rocco is very rare appearrance here in Croatia...maybe a few exempel is driveing on our streets...and i allready bought this polo brakes in willingness to put them on!! maybe some other suggestion?? help of welding maybe??
Old 15-07-2008, 14:24
Amish Raga Amish Raga is offline
we used vr6 280mm disk on an mk I, just needed a spacer and to put the original caliper in the right place! its maybe a hundred times better!
1988 MKII 2,0l 8v - Daily driver - http://www.volksforum.com/forum/showthread.php?t=44296
1992 MKII 2,0l 16v - Project car - http://www.volksforum.com/forum/showthread.php?t=44294
Old 15-07-2008, 22:54
Bas's Avatar
Bas Bas is offline
Send a message via MSN to Bas
In the Dutch section is some info, but that's in Dutch
You can use the adapters of an Audi 5cyl type 81/85 from before 1987. A passat 5cyl. from the early 80's has the same brakes, but will probably be even harder to find...
Good luck
Old 16-07-2008, 08:03
cola76's Avatar
Thanks people!!! ...few days ago i lost my mind, took the welder and make the conversion on my own!!! it looks pretty good (and pretty strong) you will see the pictures soon...it takes two days to prepare and to make hole modification!! Dont ask me why have i done that, parts are hard to find, but when you find it they are most in shitty condition, or from car accident... and after 8 months of hard pursuit i find the right wheels for my car- BBS RS771!!! JeiJJJ
Old 17-07-2008, 10:37
cola76's Avatar
This pictures was taken step by step...Your coments are welcome!!!
I make a 6mm plate and weld it all around to make sure everything is safe enough
Old 10-08-2008, 12:21
it looks pretty solid, but welding cast iron leaves me with an iffy taste in my mouth.
Old 10-08-2008, 12:40
martiepartie's Avatar
yep.. Cast iron is very brittle and welding it does not improve the strenght of the material around the weld.. The weld itself is strong, but without a serious heat treatment (normalising and annealing) it will always be a guess how safe your setup will be.
But nevertheless;
The welding looks neat and I can understand you were desperate, here in NL the rocco adapters are also hard to find..
v40 d4 r-design 2014
Volvo 244 gl 1978
Volvo 780 Bertone 1987
Mini 1275 1977
Mini 1000 1987
Old 10-08-2008, 19:22
cola76's Avatar
i used special electrode for cast iron, and weld it on 200A...i think that the 6mm metal plate i`ve used is pretty strong because the structure was not changed...i was thinking maybe to cut the spire m12 down below the egsisting m12 spire for carriers,and use bolt without head and weld it in this new spire...
i`m now at vacations, hardly waiting to come back to my garage
