Go Back   Volksforum.com > International > Watercooled technical forums > Polo MK 1,2 and 3
Old 28-07-2004, 13:00
G40Rob's Avatar
G40Rob G40Rob is offline
Question Stalks...
Hi guys, new poster here.
Just wondered, does anybody know if I can change the stalks on the steering column to something a bit, well, nicer!! ie MK3 Golf maybe...
Thanks in advance
Dubaholics
Old 28-07-2004, 13:05
sjampoo's Avatar
sjampoo sjampoo is offline
Thanks in advance
Depends..
What kinda car do you have right now?
Geld moet rollen*
Old 28-07-2004, 13:06
G40Rob's Avatar
Ive got a Mk3/2F G40.
Old 23-08-2004, 11:29
well damn Sjampoo... answer the question :p
Old 23-08-2004, 11:42
wtf is/are stalks?
Old 23-08-2004, 11:45
get a dictionary.... the wiper and blinker handles. handles are stalks
Old 26-08-2004, 09:56
why get a dictionary when we have a tjaap at this forum
Old 26-08-2004, 13:08
G40Rob's Avatar
So does anybody know?! :biggrin:
Old 18-09-2004, 18:21
You can get them from a polo 6n, the model that was introduced in '94. They're more curvey and look a bit more stylish. The tip even has a button with which you can turn on and set your interval wipes. For the the latter you need to replace your .19 relais with an .99 (from a golf mk 3 for example)
Old 21-09-2004, 19:25
G40Rob's Avatar
Thanks for the info!! Ive just fitted some Seat Ibiza stalks, and the fitted straighton. Look so much better than the originals, but I may have to look in to the Polo 6N's if I can get that wiper setting...
Old 22-09-2004, 17:39
What year is the ibiza? Chances are, the stalks are the same as the polo because the 2nd (I think it's the second) version of the ibiza is based upon the polo 6n.
Don't you have a switch on the tip? If not: indeed look into the 6n models but also check out more luxurious ibizass, maybe they are too packed with that treat. When they are don't forget to look foor the .99 relais on that car.
Old 24-09-2004, 23:45
G40Rob's Avatar
I havent got the switch on the end, but now you mention it I may have to get hold of them!!
I believe the year of Ibiza I got the stalks off were 96/97
