Old 21-10-2007, 09:35
Klapkut Klapkut is offline
Default Complete ICE Install!
Hierbij verkoop ik mijn complete ice install!
Het betreft:
1 Lanzar vibe 431 versterker:
Code:
Specificaties: 4 x 150W RMS at 4 OHMS 4 x 300W MAX at 4 OHMS 2 x 600W MAX at 4 OHMS Bridged 4 x 250W RMS at 2 OHMS Max Power 1200W Electronic Crossover Network Bass Boost Circuit Bridgeable at 4 Ohms 2 Ohm Stereo Stable Tri-Mode Capable Gold RCA Inputs Line Outs for Left and right Channels Low Pass Filter Controls High Pass Filter Controls Remote Subwoofer Bass Boost Control Power and Protection LED Indicators Soft Turn-on / Turn-off Advance Protection Circuitry S/N Ratio :90dB Dimensions: 10.25"(W) x 2" (H) x 24"(L)
1 Lanzar Vibe 241 versteker:
Code:
2 kanaals versterker inclusief bass remote # 2 x 250 Watt RMS bij 4 Ohm # 2 x 500 Watt Max bij 4 Ohm # 1 x 500 Watt RMS bij 4 Ohm gebrugd # Mosfet schakelende voeding (behoud van vermogen bij verschil in voltage) # Variabele Input Level Controls # Variabele High & Low Pass Crossover # Remote Subwoofer Bass Control # Bass Boost Circuit # Line Out # Power & Protection LED Indicators # Soft Turn On/Off # Frequency Bereik: 15 Hz-35 kHz # S/N Verhouding: 90 dB # Afmetingen: 25,65cm breed x 5cm hoog x 37,5 cm lang
1 Infinity Kappa perfect 12.1 Subwoofer
Code:
12 inch Die-Cast Hoog vermogen Subwoofer SPECIFICATIES Vermogen: 1400W max / 350W rms Gevoeligheid: 96dB Frequentie bereik: (� 1.5dB): 18Hz - 150 Hz Frequentie bereik: (�3dB): 18Hz - 150Hz Impedantie: 4 Ohm Montage diepte: 16,5cm Aluminium Conus
2 Lanzar Hr 6.2 speakers:
Code:
Standard 6.5'' (16.5 cm) Size fits OEM Cut-outs Special Chromed Mica-Poly Composite Cone Non-Fatiguing Butyl Rubber Surround 1'' High Temperature Voice Coil High Density Barium Ferrite Magnet 40 Oz Magnet Structure 1'' Silk-Neo Dome Tweeter Rubber Magnet Boot Power Handling: 140 Watts RMS /280 Watts Peak Frequency Response: 55-20KHz Impedance: 4 Ohms Mounting Depth: 2.6'' Includes Custom Wire-Mesh Grills, Wires and Installation Hardware
2 keer Lanzar VB693 Speakers
Code:
Three-Way Triaxial Speaker System Standard 6"x9" Size fits OEM Cut-outs Non-Fatiguing Butyl Rubber Surround Special Poly Injection Cone High Temperature Voice Coil High Density Barium Ferrite Magnet 1" Titanium-Neo Dome Tweeter 0.5" Polymer Tweeter Rubber Magnet Cover Power Handling: 180 Watts RMS /360 Watts Peak Frequency Response: 45-25KHz Impedance: 4 Ohms Includes Custom Grills, Wires and Installation Hardware
Alles is nog te beluisteren en het klinkt echt super!
Dozen heb ik er nog allemaal bij.
Heb het sinds mei 2007 in mijn auto zitten
Fotos:
Subkist ook inbegrepen.
Eventueel het mdf ook (dubbelle bodemplaat)
Excl. Bekabeling, zekeringhouders en verdeelblokken etc...
Vraagprijs: 600 euro alles ophalen.
Old 22-10-2007, 18:13
600 euro nu!!
