Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 19-06-2004, 16:26
Default found a great write-up about blue LED gauge lights
courtesy of "Black_cabbie" from the tex
Originally Posted by Black_cabbie
Black is back!
This is a complete guide on how to install blue LEDs in your clocks.
What we need:
8 3mm Bright Blue LEDs.
4 470Ohm Resistors 1/4Watt
Soldering Iron
Super Glue
A few loops of wire.
Soldering Boards
3mm Drill
I believe thats all.
So here we go!
Get the cluster out. I suppose you know how to do this...... :P
In my case I was swapping the ugly German looking gauge overlays with white ones I created at home. You can skip this part if you don't intent to do it.
So, I took the cluster apart and remove the needles. Very easy. Make sure you note the direction the needle rests before you pull it out. To do that, lift the needle over the pin-stop and see where it stops. Normally it should be at 0kms/0miles. Our gauges start from 20kms and 10miles but if they had a 0 thats where it would rest.
Now get two butter knives and gently slip them under the base of the needle, one on each side of the shaft, then twist the knives so they "pop" the needle straight up off of the shaft.
Undo the 2 screws on each face and you should have this on your hand.
Turn the cluster over and undo the 4 nuts in order to get the temp gauge and gas gauge out.
Once they are out you can maybe change the mileage of the odometer. The gauge I bought had a different mileage (obviously), so I wanted to match it with the real mileage of the car.
So what I did is not very professional but worked like a dream!
Undo the 2 screws on the left of the photo and remove the white long gear. It is noted in the red circle.
Now take a small philips screwdriver and insert it between the long shaft noted with the red and the black odometer cylinders. Create a small gap just enough to turn the cylinders by hand to the desired mileage. When done just make sure the cylinders are in line and the number can be read with the gauge face on.
If you have a prinout already of the overlays thats fine. Just match them over the orignal face and cut carefully.... if you don't then you can either scan yours and edit them in photoshop or you can download a ready made one from the net and then edit it according to your needs.
Thats the one I downloaded and the edited.
Edit
Mine are VDO (89-92) style gauge, so its a little different than the Motometer (84-88).
Print them on good photo paper and stick on the original faces. Cut them arround and also make the holes for the odometer. Take your time and use a BRAND NEW exacto knife.
We now proceed to the BLUE LEDs installation.
We start from the digital clock.
Once you have this in front of you, Undo the two screws noted in the rec circles.
There another 2 screws under it. To undo them lift the circuit just enough to get a small screwdriver in angle to get them out. You cannot get the board out unless you remove the flexible board completely. They are attached together.
Once all 4 screws are out you can lift the white cover and have access to the LCD screen. The LCD screen in held in place by two rubber pieces. Under the LCD screen you will find this.
This is the green film that gives that nice green light during the night (obviously). Remove that.
Now under the film you should have a transparent white diffuser. There are many ways to make this shine blue but since LEDs are directional I decided to go this route.
I drilled 2 3mm holes on its side of it. I inserted my LEDs there.
Connect the two LEDs together in parallel. You might have to trim the white plastic on the base of the cluster. You will know what I am talking about when you go back to install it.
Solder one 470Omh resistor in series.....
Connect it to a 12V source and voila!
You have your blue clock!
Solder the two wires to the inside of the old bulb holder.
Don't worry about polarity. If its the other way arround you just turn the screw in bulb holder one more turn to reverse the polarity.
I know you must be very excited by now. I was!
Now lets go on to the rest of the cluster.
Suppose that you have the gauges and the needles and everything back together.....
On top of the cluster you can see white cover.
Carefully remove that and you should have a green film under it similar to the one you found under the digital clock earlier. Remove it completely and never think about it again!
There are many ways to make the light from the LEDs diffuse to have an even light inside the cluster. I couldn't find a proper white diffuser so I just though of diffusing my existing blue LEDs by sanding down a bit their tip. I few trials with the LED connected to a power source created my desired result.
I used these cheap soldering boards because they were very easy to shape.
These are the candidates....
The previous bulb covered with a blue cap!
3mm and 5mm Blue LEDs
Although 5mm were brighter, I chose to use the 3mm due to their smaller size.
So I used 6 LEDs soldered on the boards and cut to fit the top of the cluster.
Once you are satisfied with the angle and the light inside the cluster use some instant glue to hold the boards in place.
Solder all the LEDs in parallel and leave two wires long enough to connect to the outside of the cluster.
These two wires are going to be connected with a resistance in series to the original bulb holder shown here.
Do a couple of trial runs to see if all LEDs glow before you put the white cover back on.
If you are unsatisified with the glow of the LEDs you can put a couple more resitors in parallel to reduce the overall resistance. So far 4 470ohm resistances worked ok. The LEDs are still working after having them on one whole day.
In case you are wondering why put the resistors in parallel I can tell you that the 1/470+1/470=2/470. Invert that and you have a new resistor of 235Ohms. Just for your information.
If you did everyinth carefully and slowly you should have something similar to this....
I am very pleased with myself.
But since I am a perfectionist I found two problems on the completed project.
1st, the Needles are red and you cannot see them in the dark.
Problem solved with some Fluorescent Orange paint.
2nd, The tacho overlay looks "funny". Thats because the overlay is originally designed for a motometer gauge which is a bit different. No problem since I wanted to redesign the overlays in the first place.
Old 19-06-2004, 17:16
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Very nice...
Only the text on the rev meter is not straight
Old 20-06-2004, 22:57
black_cabbie black_cabbie is offline
Originally Posted by sjampoo
Bricobi ?? This must have been some belgian chap..
Look ok, but the pics are a bit 'neon-blue-ish'.. whould like a bit darker, not so 'black-light' finish..
Bricobi provides me with all the necessary tools.....
Btw, the pics don't do it justice. Its not as bright as it looks. Trust me its not as ricy as you think. People notice me during the night though!
Old 01-07-2004, 00:40
would you mind if we use this for our new "how-to" page we're going to enclose to this forums?? you'd be getting all the credits offcourse...
Old 03-08-2004, 18:23
Batan's Avatar
Batan Batan is offline
Nice looking gauges. We used to do that and it looked like this(www.duostyling.com)
duostyling instruments(by badzak design) - made just for us enthusiasts!
91 GTI 8V / 92 GTI AEG 8V / 61 Ghia Coupe
Old 21-11-2012, 04:46
Radnunt Radnunt is offline
Originally Posted by black_cabbie
Bricobi provides me with all the necessary peimar led lights tools.....
Along with do you provide LED lights. I am looking for some expensive strips of led lights
