Go Back   Volksforum.com > International > Off Topic > Car Café Int
Old 21-07-2006, 17:16
PerL's Avatar
PerL PerL is offline
Exclamation The difference of 3mm and 1.6 mm tire thread depth on wet roads.
UK's Autoexpress and Continental Tires have made this video to show the difference of legal 1.6 mm tires and less worn tires with 3 mm thread depth. The difference is shocking, to say the least!
http://www.autoexpress.co.uk/autoex...fety_shock.html
The tire in the test is the Continental SportContact2
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 22-07-2006, 21:17
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
hmmm... i think i've seen enough, no more tires for me under some 2.0 - 2.2 mm's
Passat B1 LS
Passat B8 Businessline R
Old 23-07-2006, 19:54
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
Wow, quite a shocking result, never would've thought it made THAT much difference. Time to review the minimum tread depth and adjust it to modern automotive products?
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 23-07-2006, 20:06
BBS-roy's Avatar
BBS-roy BBS-roy is offline
Oeps
Bla Bla, Bla
Old 23-07-2006, 22:41
Marco's Avatar
I think you're right, i think it should be some 2.5 or maybe they must make some better tyres
Passat B1 LS
Old 24-07-2006, 00:34
PerL's Avatar
I agree that the minimum should be 3 mm just like for winter tires, but then again, the tire in the test isnt the very best in the rain either, as the SportContact2 has no sipes to push the water out to the sides. And when worn to 1.6 mm it's very close to a street-legal racing slick tire. So, it's really the most extreme case were seeing in this video.
