Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk1
Old 23-05-2006, 00:51
SKINNY_PEDAL SKINNY_PEDAL is offline
Send a message via MSN to SKINNY_PEDAL
Default turbo with carburator?
tried searching but nothing was really coming up. i know it is possible. but i want to keep my 1,6 in my car with a webber or webbers but would like to run a turbo as well. anyone know anything?
while im at it, could i use a 32/36 webber on the rabbit?
Old 23-05-2006, 04:56
FDL FDL is offline
Well, as far as I know, it can be done. The only thing that I can't really confirm is the space necessary on the rabbit. On longitudinal engines it fits perfectly, just take a look:
(Weber 44 IDF + Turbo Biagio .50/.70 Bi-Pulsative)
So, you just need to see if there is SPACE for it. The turbo for itself can be placed on any engine, as long as the engine isn't f***** up...
[]'s
Old 23-05-2006, 14:26
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
Well, there's two ways to do this really.
Number 1 is as seen above, feeding compressed air through the carburator (used a lot in Brasil!). You'll need to build a pressure dome around the carb so as to compensate for the increased pressure passing through the carb, or you'll kill the venturi effect a carburator is based on. If you understand your carburator very well you can skip the whole pressure dome and do it the way as pictured above, but you must be very certain that the floatbowl(?) is also pressurized by the turbo so as to compensate for the increased pressure and maintaining the venturi effect.
Number 2 is to place the carb in front of the turbo. In effect, the turbo takes in air (actually, mixture) through the carb. This method is easier to build and tweak, downside is you'll not be able to place an intercooler (instead of air, fuelmixture will pass through and all kinds of weird stuff will start to happen).
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 23-05-2006, 14:27
Stijn's Avatar
Class of 2003
Damn, just saw your location: DesMoines WA?? I used to live there You happen to be DCI material?
Connie: 16.
Connie: Mom!
