te koop een senergy dvd speler
nieuw 199 euro 2 weken oud 150 euro Specificaties » 1 DIN in-dash DVD speler, kofferbak model » Bedienbaar met remote of front paneel » Ondersteunt CD(-RW)/(S-)VCD/DVD/MP3/JPEG » Anti-vibratie - ESP (ongeveer 3 sec.) » Skip fwd/rev - Titel/Hoofdstuk/tijd funktie » Trick modes (slow/fast x2, x8, x16, x32) ![]() een senergy beeld scherm 6 inch in nieuw staat nieuw prijs 269 euro nu 180 euro foto komt nog jvc radio dvd speler speelt alles af 4mnd oud kd-dv5101 ![]() Merk JVC Aantal uitgangen 4 Bluetooth Zonder bluetooth CD-Player / -Recorder CD-Player Compact Flash Card Nee Componenten type Autoradio Diefstalpreventie Afneembaar paneel DVD-Player / -Recorder DVD-Speler Geintegreerde telefoon Nee Grootte in DIN 1 DIN Memory Card Slot Zonder Memory Stick Nee Microdrive Nee MP3 weergave Met MP3 weergave Multimedia Card Nee RDS Met RDS Secure Digital Card Nee Smart Media Card Nee TMC Zonder TMC Touchscreen Nee USB Zonder USB Vermogen in watt 200 Wisselaar Met wisselaar WMA weergave Ja xD Card Nee 190 euro in nieuw staat 2x 1000 watt jbl woofers in losse kist 90 euro per stuk ![]() 1 rockfort fosgate 301s amp 175 euro zijkappen missen The Rockford Fosgate Punch 301S slams your speakers with a one-two combination, so they deliver the high-end musical performance you demand. 75 watts RMS x 2 at 4 ohms 150 watts RMS x 2 at 2 ohms 300 watts RMS x 1 bridged output at 4 ohms stereo or bridged mono output 4-ohm stable in bridged mode Tri-Way capable requires a 10-gauge wiring kit with a 30-amp fuse wiring and hardware not included with amplifier variable high- and low-pass crossovers (50-250 Hz at 12 dB/octave) MOSFET power supply and output devices MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality NOMAD advanced protection circuitry for "intelligent" shutdown protection variable Punch Bass (0-18 dB boost at 45 Hz) speaker- and preamp-level inputs 11-1/8"W x 2-7/16"H x 9-7/8"D More [+] ![]() 1 rockfort fosgate 201s nieuw alleen geprobeert boekjes en doos aan wezig 225 euro Description The Rockford Fosgate Punch 201S slams your speakers with a one-two combination, forcing them to give up the high-end musical performance you demand. 50 watts RMS x 2 at 4 ohms 100 watts RMS x 2 at 2 ohms 200 watts RMS x 1 bridged output at 4 ohms stereo or bridged mono output 4-ohm stable in bridged mode Tri-Way capable requires 10-gauge power and ground leads wiring and hardware not included with amplifier 120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave) MOSFET power supply and output devices MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality NOMAD advanced protection circuitry for "intelligent" shutdown protection selectable Punch Bass (0/6/12 dB boost at 45 Hz) speaker- and preamp-level inputs 10-1/8"W x 2-7/16"H x 9-7/8"D More [+] ![]() alles in zeer goede en nette staat en geen rommel en het zijn vraag prijzen verder diverse aansluit materiaal zo als voedings kabel ed alles kan evt ingebouwd worden naar wens pb voor info of bel 0646047890 |
kom je vandaan frank ??
'91 Volkswagen Golf II GTI 16VT Edition One '10 Audi A4 B8 Avant |
het altijd gezellige apeldoorn
hoe gezellig ik het daar ook vind, is me net iets te ver naast de deur ,srry ![]()
als je genoeg afneemt wil ik wel je tegemoed komen
had eigenlijk alleen interesse in de radio...
kan hem evt opsturen naar je pb maar voor info hier over of via msn frankpr1@planet.nl
