Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 04-04-2006, 11:36
BMC BMC is offline
Default wheel bearing
does a frontwheelbearing of a A3 golf fit in an A2 golf? measures seems the same, 72 and 40 dia, 38 thick..
thanks
Old 04-04-2006, 21:50
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Can you give us some more specs of your A2? So i can compare some part numbers and so
Passat B1 LS
Passat B8 Businessline R
Old 05-04-2006, 08:59
BMC BMC is offline
its An A2 turbo diesel 1.6 jan 1991 (btw, heb zelfde vraag in nl gedeelte gesteld ;-) )
Old 24-04-2006, 13:05
Housey's Avatar
Housey Housey is offline
Send a message via MSN to Housey
if the measures are the same... go for it
don't reuse wheelbearings (as far as i remember, you can't reuse then anyway)
Old 29-04-2006, 00:36
pikzibner's Avatar
pikzibner pikzibner is offline
Send a message via ICQ to pikzibner
Yes it fits. I have them on my golf and G60 brakes
TDI POWER
http://www.vwclubcroatia.com
