Go Back   Volksforum.com > International > Aircooled technical forums > Type 2 (bus '49-'67) (bus '68->)
Old 09-11-2005, 21:23
gutte gutte is offline
Default how do i let the air out of my cooling system type 2 1600 diesel from 1985.
Old 10-11-2005, 01:10
PerL's Avatar
PerL PerL is offline
You need to raise the front end of the van up at least 20 cm and purge the air via the bleeder screw on top of the radiator. The engine needs to be hot of course, so the thermostat will open and circulate the coolant to the front end of the van.
1999 Audi A6 quattro
1987 Audi Coupe quattro
