Go Back   Volksforum.com > International > Aircooled technical forums > Type 2 (bus '49-'67) (bus '68->)
Old 21-10-2005, 06:53
jered's Avatar
jered jered is offline
Default Will having the wrong MAS effect a FI engine?
I had won some MAS (mass air sensors) on ebay in a lot... after relisting the incorrect one for my van (got one for my 77 and one for 78-79's).
Needless to say the part number for my VW Westfalia MAS is
BOS-0-280-200-018
I decided to swap the one on my westy with the replacement one I had because the one on my car stuck and I thought it could have issues with effecting the running operation of the motor.
The part installed on mine was
BOS-0-280-200-020 however according to www.cip1.com the correct part number is the 018 MAS...
Now, I have the correct part on the van according to what cip1's site says is the correct part... Is there any negative side effects that could have been temporary or permenent with the incorrect MAS on it?
Just wanted to verify and make sure I'm good to go...
Thanks Jered
1977 Westfalia Campmobile
New paint, new exhaust system, replacement H4 headlight conversion, new tail light assemblies, JVC CD player, Infinity 6.25 and pioneer 6x9's...
Old 22-10-2005, 23:15
jered's Avatar
wow... no replies...
Anyone know who I can contact about this? Any info would really be nice...
Thanks for the help. Jered
Old 22-10-2005, 23:24
berendd's Avatar
berendd berendd is offline
maybe the engine has runned a bit too rich or lean for a while. Don't think it'll be a problem.
only if you have a lambda be careful with running too rich, could damage the lambda.
Old 23-10-2005, 03:47
jered's Avatar
whats a lambda?
Old 23-10-2005, 13:27
PerL's Avatar
PerL PerL is offline
The Lambda is the oxygen sensor.
Have you tried the Type 2 list? Found at http://www.type2.org. Or maybe the forums at shoptalkforums.com or thesamba.com. The Type 2's were sold with carburettors well into the 80s here in Europe, so I think it will be hard to find some good answers here.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 24-10-2005, 00:18
jered's Avatar
nope... no O2 sensor....
is there a good forum for the US for type 2's? or a type 4 motor forum?
Thanks
Old 24-10-2005, 00:20
vwfreaks.nl's Avatar
vwfreaks.nl vwfreaks.nl is offline
Old 07-10-2008, 11:24
77VWBusDude 77VWBusDude is offline
Hey, this unanswered thread popped up on the first page when I Google searched "Type2.com", so I figured I'd register and answer it
I posed the same question over on thesamba.com a little while back, and this is the response I got:
The 018 was superceded by the 020, so if you were to go into a VW dealer and order a AFM(airflow meter)for your '76 or '77 they would sell you a 020(if they were still available today).
So you're ok. They are the exact same part, the different #'s just tell you how old they are. The door/flap in mine was sticking too, so I sanded the housing a little to free it up, since; when I popped the plastic top off the AFM, the electrical components inside looked new, therefore I wanted to get some more miles out of it.
