Go Back   Volksforum.com > International > Watercooled technical forums > Polo 6N, 6N2, 9N and 6R
Old 12-10-2005, 19:33
PerL's Avatar
PerL PerL is offline
Default Defective power window, 6N
A guy at work has a 6N (99 if I remember correct) where the driver's power window isnt working anymore. I agreed to fix this for him. Now, I assume that it is the cables in the door jamb that are the problem, but is there anything specific, known problems, that I should check, or is it correct of me to assume that it is the cables that are the problem? Any points or tips are welcome.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 12-10-2005, 19:49
vwleusden's Avatar
rust i think... possible broken.
2011 Ford Ka
Old 12-10-2005, 20:04
Melvin Melvin is offline
that is a known problem, because the motors are almost completely from plastic...
Old 13-10-2005, 21:14
PerL's Avatar
Had a look at this Polo today (which is an '01 6N2 btw) and the problem was as I suspected, broken wires in the door jamb.
