Go Back   Volksforum.com > International > General > Who is who
Old 02-11-2017, 13:31
cupracraig cupracraig is offline
Default Mk2 Golf 8v into 20v, England
Hi, i thought i'd better sign up as i've been looking at this forum for a while and the facebook page and thought i'd share my journey on my MK2.
well i picked up a 1991 8v back 2 years ago.
I drove it about for some time and then decided on some maintenance and a change to 20v. i've skipped a lot but here's some of the journey.
The front drivers side wishbone joint was looking a bit sorry for itself :o
so ive added on some S2 twin pots
changed the charge pipe setup for that of a k04
new genuine mounts:
got it all in the car
a couple of nights of work and its back like this:
just loosly put in the new subframe while i clean up the engine bay and the old power steering rack
the new daily :violin:
also ordered a new trackslag exhaust , the slanty tip one to look OEM.
its no longer my daily driver but also not a show car
this was from 2017 Volksfest
Cooling sorted, plumbed, bled..ready to drive! now for some dry weather
painted my intercooler pipes and fitted a new larger radiator. Just waiting on the fan bracket so that i can add the fan and fill it up with coolant again.
Currently awaiting some parts so that i can refurbish the rear axle, brakes and anything else on the rear. also splitting the BBS and going wider with those.
thanks
for looking
Old 02-11-2017, 13:38
Tommy's Avatar
Tommy Tommy is offline
Nicely done and great color!
Old 02-11-2017, 17:05
thanks it was a steep learning curve as i've never worked on cars before
Old 05-11-2017, 20:02
Great car!
Old 06-11-2017, 09:30
Great car!
thanks, its getting there slowly
Old 07-02-2018, 11:26
been a bit of a while since i last updated
i replaced the fuel tank straps with new stainless ones :
20171022_144829 by Cragmire40D, on Flickr
20171022_144839 by Cragmire40D, on Flickr
the mounting points were very clean
20171022_142710 by Cragmire40D, on Flickr
had the original RA wheels refurbished and new tyres all over
20171030_213752 by Cragmire40D, on Flickr
drove it a few times before the weather got bad
20171103_113817 by Cragmire40D, on Flickr
Built a false floor for a bit more sound
IMG_20180122_200616_046 by Cragmire40D, on Flickr
Decided to move away from the tapered bearing setup and go for a 6N2 GTI rear setup
20180115_112944 by Cragmire40D, on Flickr
then got excited and decided to just refurbish the whole rear axle
Got a snapped bolt
19905182_10156238860064258_4425863930378189923_n by Cragmire40D, on Flickr
cut out the old bushes and housings
20180203_223730 by Cragmire40D, on Flickr
20180204_140736 by Cragmire40D, on Flickr
Old bush vs new
IMG_20180122_200839_578 by Cragmire40D, on Flickr
Refurbished the mk2 rear calipers, adding stainless nipples with new covers and painted in Dark Anthracite which i will paint the fronts in too
20180206_182456 by Cragmire40D, on Flickr
20180206_182202 by Cragmire40D, on Flickr
Old 07-03-2018, 00:42
Mad_Uwe's Avatar
Mad_Uwe Mad_Uwe is offline
Very nice car!
Prius3
Superb Combi 1.6TDI Hartog optimized
Z3 M-Coupe S54 Phoenix Gelb nr. 27/269
Boxster S 987 48dkm
Ducati 916, 748SP, 999S
Suzuki GSXR750 ‘87, ‘91, ‘91
Old 07-03-2018, 12:29
bit of an update:
more brake parts updated:
20180211_091136 by Cragmire40D, on Flickr
IMG_20180217_161318_976 by Cragmire40D, on Flickr
Rear beam got blasted and primed:
IMG_20180216_194958_917 by Cragmire40D, on Flickr
Found a little issue:
IMG_3504 by Cragmire40D, on Flickr
Raptor painted my rear axle
20180224_224417 by Cragmire40D, on Flickr
20180224_194436 by Cragmire40D, on Flickr
Stripped the Eibach ARB and did that too
20180304_200032 by Cragmire40D, on Flickr
20180226_221319 by Cragmire40D, on Flickr
20180306_204840 by Cragmire40D, on Flickr
I forgot to fit the ARB, so need to do that tonight and then i can get the alignment on the rear set and bolt it all up tight again befroe fitting the brake lines etc
Old 07-03-2018, 22:01
R-oy R-oy is offline
Calipers looking clean. what type of paint have you used? Spray/Brush on?
Old 08-03-2018, 09:58
its a high temperature spray on paint, i perhaps should have laquered them but i have not, so lets home i dont have to paint them again soon
Old 09-04-2018, 09:53
Tempting to build one myself
Old 16-04-2018, 13:16
very worth while, great fun aslong as you dont start aiming for big bhp..keep it simple, keep it realistic and enjoy
Old 17-04-2018, 21:23
If the weight stays around a tonne any hp up to 200 feels very nimble I'd reckon.
Old 23-04-2018, 08:44
the Trackslag exhaust hass been so good to listen to lately, echos so nicely up through the gorge
IMG_20180420_224532_960 by Cragmire40D, on Flickr
IMG_20180418_193038_618 by Cragmire40D, on Flickr
Old 20-06-2018, 16:24
the cars back how i want it, i rebuilt the RS' with wider lips and picked up some narrower adapters.
IMG_3571 by Cragmire40D, on Flickr
IMG_20180617_171944_919 by Cragmire40D, on Flickr
IMG_20180519_215756_524 by Cragmire40D, on Flickr
upgraded from mk3 to G60 top mounts
20180501_190524 by Cragmire40D, on Flickr
Old 23-07-2018, 14:28
got snapped up a local car hot spot a few weeks ago
jdh._snaps_BlSd5WoHQEU by Cragmire40D, on Flickr
Old 24-07-2018, 15:28
Cool ride mate !!
Old 02-08-2018, 17:27
Testing out the new smart phone camera and im happy with the vast improvement over the old Galaxy S5 i had for 6 years!
Old 02-08-2018, 23:04
Very cool..! What is it like to drive? Comfortable on moterways?
