![]() AIM mychron 3 XG LOG. (gebruikt)
Datalogger en dashboard. Digitale toerenteller,snelheidsmeter en div andere aanduidingen zoals olietemp watertemp, oliedruk,brandstofdruk en luchtdruk in airbox en versnellings indicatie en schakellampen en veel meer zoals G-sensor Zeer uitgebreid inzetbaar! Geen goedkoop dash of immitatie. Kan ook geschakeld worden aan KMS vrij programeerbare injectie. Of VW CAN. Hieronder tekst gekopieeerd van site. The MyChron3 Gold Auto is designed for advanced automotive racers who need to manage numerous variables and analyze their data on their PC. It is designed for multi-cylinder automotive and motorcycle racing, and features an integrated CAN/RS232 connection. This interface enables the XG LOG to directly connect to the engine managment system on many race vehicles. This connection simplifies installation, as the ECU connection often provides data from the existing sensors, reducing the need to deploy sensors for the gauge. The CAN connection provides access to dozens of channels, and the XG Log can record and display them. In addition, the XG Log has 5 analog input channels and all the features of the MyChron3 Gold Auto, incuding a lateral G sensor, speed sensor, sampled or calculated gear display, 8 MB of memory and up to 200Hz sampling and recording per channel. The lateral G sensor lets you create a map of the track when you download the data to your PC. The 5 input channels are fully configurable analog inputs: connect sensors for temperatures (thermocouples – thermoresistors), pressures (Oil – Fuel – Airbox), potentiometers (suspension travel, brake pedal displacement, throttle pedal displacement, steering angle, roll angle), Lambda (air fuel ratio), “on-board/stock” sensors, or custom made sensor configurations, gear position (either sampled from an “on-board” gear sensor or calculated from RPM and speed values), and lap times. The MyChron3 XG LOG features a beautiful backlight display and built-in 200 Hz data logger. View the playback on screen or download the data to your PC via the high speed USB port. Use our powerful Race Studio 2 software to analyze the data on your PC. ![]() 450 euro
Scirocco 1 `78 Autocross Hustler GT Buggy project `73 Scirocco GT2 project `91 VW vrije-standaard cross project Daily : Scirocco GT 1.6 '85 47.000km Golf GTI `81 Sold! |
![]() Is deze apk "proof"?
![]() Wat versta je onder apk proof?, ik zou niet weten waarom niet.
![]() Nee, mychrone 3 heeft geen knipperlicht en groot licht functie etc, dan moet je echt een strada of pista voor hebben.
![]() Klopt maar daar kun je gewoon losse lampjes voor gebruiken. Zo heeft kameraad dat in zijn vw buggy en nooit geen probleem met APK.
![]() Eigenlijk is de strada of pista beetje appels en peren vergelijken als je kijkt naar de prijs, deze zitten op 1000 en 1700 euro ex de BTW. Als je dan hier 4 lampjes/ledjes bij moet plaatsen is het verschil wat deze kost en die andere nogal flink. Bij een trackbuild auto is het ook ideaal bij een zitpositie die flink naar achteren is gebracht. Het display kan probleemloos op het stuur gemonteerd worden door de flexibele kabel, ook een afneembaar stuur is geen probleem er zit een stekkerverbinding in de kabel.
Scirocco 1 `78 Autocross Hustler GT Buggy project `73 Scirocco GT2 project `91 VW vrije-standaard cross project Daily : Scirocco GT 1.6 '85 47.000km Golf GTI `81 Sold! Last edited by sciroccoGTII : 08-02-2016 at 20:36. |
![]() Verkocht , slotje graag
