Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk3
Old 12-08-2005, 21:31
VWMAN's Avatar
VWMAN VWMAN is offline
Default What is the front disc size of 1995 Golf GTi 16v ?
is it 288mm or 280mm ??
POLO 1.6 8v '98
POLO 1.4 16v '98
Old 12-08-2005, 22:13
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
As far as i can see only the VR6 of that year had 288mm. The 16v has 280mm
Passat B1 LS
Passat B8 Businessline R
Old 12-08-2005, 22:31
VWMAN's Avatar
1996 models have 288m discs, dont they ?
some web sites say that post 95 is 288mm ; pre 95 is 280mm...95 is in the middle ..it isnt clear...
Old 13-08-2005, 22:25
PerL's Avatar
PerL PerL is offline
I had a look in the parts catalogue, for 95 it says that both the 8V and 16V GTI uses the 280 mm discs, while the VR6 had the 288 mm discs. For the 96 model year, the parts catalogue doesnt break the disc size down to engine versions.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 14-08-2005, 00:19
VWMAN's Avatar
thank you guys....
After some research 1997 and 1996 models 16v have 288mm....1995 models have 280mm...
