Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 28-07-2005, 18:46
matt16vwales matt16vwales is offline
Default Replacing starter motor
Can anyone give me some tips on lining my new starter motor up with the gearbox. The gearbox dropped after removing the faulty motor, now i can't even put back my original starter. It is very close in fact i can see the bolt pushing the bracket as i tighten the bolt but it doesn't seem to be catching the threads.
Old 28-07-2005, 19:03
VeeDubber's Avatar
Volksforum Crew - S2 Racer
carefully jack up the tranny?
Old 29-07-2005, 07:09
Is your gearbox connected to the engine with some other bolts? It should, so it wont drop when you remove the starter motor.
2006 BMW 320d Touring
2001 Golf Mk4 Variant 1.6 16v
Old 29-07-2005, 17:33
There are only 3 bolts connecting the starter motor and when these are undone and the starter is removed the gearbox lowers a few inches? You are supposed to support the gearbox when removing the starter but the gearbox still dropped - maybe i didn't have the jack in the right place? Hopefully i will be able to reposition the upper and lower brackets that the starter motor bolts onto.
Old 29-07-2005, 20:02
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
I always placed the jack just under the flywheel housing. Alsways worked perfect. The problem is that one of the bolts of the starter is also a bolt for connecting the gearbox to the engine.
Suc6
Old 30-07-2005, 00:45
dubstarmk2 dubstarmk2 is offline
just jack it up and giggle the truk out of it, and watch the bracket on the other side of the engine mount isnt twisted
Old 30-07-2005, 02:30
oh, I understand, your gearbox with engine dropped. And now the mounting holes don't line up.
Just jiggle a bit, jack it up, it's not that difficult, i did it today in 15 minutes.
Old 30-07-2005, 14:30
Smile
Thanks for all your help, i've got the new starter motor fitted. The reconditioned one i bought was shorter and fatter so it was a lot more difficult doing up the existing bolts and aligning them. The top bolt was a pain in the ass!! I used a long lever on the bracket to pull the bracket away from the engine and the thread caught. The brackets have holes for levering it into position. I put the jack underneath the flywheel and aligned the bottom two bolts first, then i levered the top bracket so the bolt would locate. Just in case anybody else has to do this!
Old 31-07-2005, 15:01
Marco's Avatar
ok, good to hear you fixed it
