Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 28-05-2005, 17:32
matt16vwales matt16vwales is offline
Default Mk2 16v Starting problems
My golf has been off the road for a few weeks and now i can't get it started.
I have recharged the battery but still won't start, the voltage reads 12.87 using a multimeter. The starter motor clicks and there is a wheezing noise from the ignition system?
However it won't start any ideas?
Old 30-05-2005, 02:11
veedubluv04's Avatar
veedubluv04 veedubluv04 is offline
Send a message via MSN to veedubluv04
starter could be sticking try hiting it with a hammer fairly lightly, test the starter by earthing a screwdriver to the block to see if it turns.
other than that check your wiring and try holding the key on for a while sometimes that helps .......
Old 28-06-2005, 18:44
Default Still won't start
Thanks for replying and sorry i have not got back sooner, i have tried tapping it with a hammer and holding the ignition key down for a few seconds but will only start by bump starting. Could this still be a sticking motor or is a replacement in order?
Old 29-06-2005, 00:30
PerL's Avatar
PerL PerL is offline
If the battery's been fully charged but there is no life even when hammering on the starter, it's probably the internal relay inside the starter solenoid that's the problem. I dont think you can buy the solenoid separate, so you may have to replace the starter for a new/used one.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 07-07-2005, 09:47
berendd's Avatar
berendd berendd is offline
it can be the relai in y'r fuse box too, or a cable that's missing.
take the wire from the starter, let someone turn the key and check the voltage on the wire too see if everything but the starter works.
Old 07-07-2005, 09:58
My battery was broken resulting in the same problems. Perhaps switching the battery for a quick test is an option?
2006 BMW 320d Touring
2001 Golf Mk4 Variant 1.6 16v
