Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 24-04-2005, 22:43
novaboy16 novaboy16 is offline
Default European Motor Code Info
Hey guys...I recently picked up a 2E bottom end out of a SEAT...I was looking around for pistons that are bored over inbetween 20-50 over...
I checked Gebert Autohaus here in Kaiserslautern, Berger Autotiele and Roiger as well...
Does anyone have any specs they can pull up on this motor or pistons that would work? I know it was put in VWs from 91-94...It is a 2.0l and had 115hp...same as the ABA...
Any info would be great and someone who has dealt with this motor as all
Also, would I be better in just using the old ones and honing the walls and lightening and balancing the bottom end, or trying to find some pistons
Anyway, thanks guys...later
Dave
Old 26-04-2005, 20:25
Can anyone help me out??
Old 26-04-2005, 23:27
PerL's Avatar
PerL PerL is offline
The pistons in the 2E engine are 82.5 mm, I cant find any oversize pistons stock from VW. All the 1984 cc engines uses pistons this size, and are found in Golfs, Jettas, Corrados, Audi 80, 100, A6 with various engine codes.
As long as the piston bores arent worn, you should be ok with honing the walls and installing new rings.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 27-04-2005, 04:37
Thanks PerL...
One more question...Has anyone ever thrown a golf 2 digifant 2 head on to a 2E block...from my perspective, it looks a little bigger
Old 27-04-2005, 17:29
PerL's Avatar
The head should fit, but I'm no wizard when it comes to these engines.
Old 27-04-2005, 17:36
sjampoo's Avatar
sjampoo sjampoo is offline
2E is the lumb used in the 8v GTI... so similar to other blocks, probably everything will fit
Geld moet rollen*
Old 28-06-2005, 04:12
TwinScrew20v TwinScrew20v is offline
Send a message via AIM to TwinScrew20v Send a message via Yahoo to TwinScrew20v
Does the 2E use 159mm pistons like the ABA? Id be extremely surprised if the head wouldn't match up (even the 20v head fits early blocks) Double check the piston wristpin size in the rod before buying pistons...The 159mm rod motors use a 20mm wristpin and most other Pre-Mk4 motors use a 22mm wrist pin. One thing to keep in mind
Old 28-06-2005, 17:27
MelG60 MelG60 is offline
2E is the highblock with 159mm rods. 20 mm pins.
1991 Golf GTI 20v 4x4 677pk
1989 Golf 20v turbo 4motion
1990 Golf GTI G60
1990 Golf GTI 16vG60
1991 Golf GTI G60
1991 Golf GTI Edition one G60
1983 Golf GTI 16vG60
1983 Golf GTI G60
2000 Audi S3
