Go Back   Volksforum.com > International > Watercooled technical forums > Polo MK 1,2 and 3
Old 08-02-2012, 20:20
wiebenaberman wiebenaberman is offline
Default 1984 VW 1.3 Polo GT starting problems
Good day everybody
I have a question...
I have got a 1984 VW 1.3 Polo GT. The problem is, he refuse to start during the cold period. Not only when it is freezing -15 but also when it is about -2. Does anybody know what it could be? Or what I need to do? By warming the carburator with a paintstriper, he will start, but using a jumpstarter towards another car, he doesn't start. Currently I am using a 45AH, 400A startcurrent battery.
I would like to hear from you
kind regards
wiebe naberman
Old 08-02-2012, 20:31
Bas's Avatar
Bas Bas is offline
Send a message via MSN to Bas
Do you press the gas pedal fully down once before you start? By doing this the automatic choke is activated.
Old 08-02-2012, 21:23
yes I heard that I need to do that, but how can I see if it works? Does anything in the carburator need to change what i can see?
Old 18-10-2012, 14:00
Audi1981's Avatar
Audi1981 Audi1981 is offline
5 Cylinder Turbo Donateur
At the temperatures you are discribing the fuel doesn't evaporate so easily, so it just condenses to the surface of the intake manifold, by pressing the accelerator pedal 2 times, you activate the autochoke and pump extra fuel into the engine, so it will start better. Autochoke can be checked by removing the airfilter and, with a cold engine, pressing the accelerator pedal, in good condition, your autochoke should then engage wich can be observed as the top butterfly valve in your carb closes. Any adjustments can be made by loosening the autochoke housing and, with pressed accelerator pedal, rotating the housing so that the valve closes to a gap of +/- 6mm. For the adjustment i allways use a 6mm drill.
"Surfin' down the avalanche!"
Audi A4 Avant 2.0 20V 2005
VW Lupo 1.4 16V BSO racer
