Go Back   Volksforum.com > International > Technical > Wheels and tires
Old 25-01-2005, 17:52
field field is offline
Default 13 inchers!!
can any one help, going to get me some 13" wheels for me 79 golf. thinking about 13" x 7 on front and then 13" x 8 on back. what ET (means off set - right?) will i need for front and back, should it be the same?, and is there anything else i need to know. don't really want fit spaces if i can help it!
Old 25-01-2005, 18:45
Rickyrick Rickyrick is offline
Send a message via MSN to Rickyrick
These are mattig's, 7j in front and 8j at the back...rocks
It don't matter what Volkswagen you drive. If you ain't Rubbin, you ain't Dubbin.
Old 25-01-2005, 21:57
Gert's Avatar
Gert Gert is offline
From what ive seen over the years is that at the back 8 x 13 et 0 did fit ... with extreme lowering .
Stay around 7 x 13 et 20 and ur more then safe .
Wheels are a bit cheaper in that range too coz the lower the et and the wider the wheel the bigger the demand .
Hope this answer helped u
Old 25-01-2005, 22:13
et = offset for our overseas friends
Old 07-04-2005, 03:06
veedubluv04's Avatar
veedubluv04 veedubluv04 is offline
Send a message via MSN to veedubluv04
im looking to put 13x8's et1 on my mk2 tryin to get that oldskool look but i recon im gonna need to change the brake set up i think although im not certain eny advice would be great????????????????????????????????
