Old 04-10-2009, 13:50
Default Bosch Codering
Misschien handig voor iemand, Bosch codes / Bosch Codering:
Bosch Terminal Designations
thanks to Unca Joel Walker
From Bosch Automotive Handbook, 3rd edition
Terminal Designations (Excerpts from DIN Standard 72 552)
The terminal designations do not identify the conductors, because device
with different terminal designations can be connected at the two ends of
each conductor. If the number of terminal designations is not
sufficient (multiple-contact connections), the terminals are
consecutively numbered using numbers or letters whose representations
of specific functions are not standardized.
Terminal Definition
IGNITION
1 Ignition coil, ignition distributor, low voltage
(Ignition distributor with two separate electrical circuits)
1a to ignition contact breaker I
1b to ignition contact breaker II
2 short-circuit terminal (magneto ignition)
4 Ignition coil, ignition distributor, high voltage
(ignition distributor with two separate electrical circuits)
4a from ignition coil I, terminal 4
4b from ignition coil II, terminal 4
15 Switched + downstream of battery
(output of ignition/driving switch)
15a Output at dropping resistor to ignition coil and starter
GLOW PLUG AND STARTER SWITCH
17 Start
19 Preheat
BATTERY
30 input from + battery terminal, direct
30a input from + terminal of battery II
(12/24 V series-parallel battery switch)
31 Return line to battery
- battery terminal or ground, direct
31b Return ine to negative battery terminal or ground, via switch
or relay (switched negative)
(12/24 V series-parallel battery)
31a Return line to - terminal of battery II
31c Return line to - terminal of battery I
ELECTRIC MOTORS
32 Return line
(Polarity reversal possible at terminals 32-33)
33 Main terminal connection
33a Self-parking switch-off
33b Shunt field
33f For second lower-speed range
33g For third lower-speed range
33h For fourth lower-speed range
33L Counterclockwise rotation
33R Clockwise rotation
STARTER
45 Separate starter relay, output; starter input (main current)
45a Output, starter I
Input, starters I and II (Two-starter parallel operation)
45b Output, starter II (Two-starter parallel operation)
48 Terminal on starter and on start-repeating relay for
monitoring starting procedure
TURN SIGNAL FLASHER
49 Input
49a Output
49b Output, second turn-signal circuit
49c Output, third turn-signal circuit
STARTER
50 Starter control (direct)
50a Output for starter control
(Series-parallel battery switch)
50b Starter control with parallel operation of two starters with
sequential control
50c Input at starting relay for starter I
(Starting relay for sequential control of the engagement
current during parallel operation of two starters)
50d Input at starting relay for starter I
50e Input, Start-locking relay
50f Output, Start-locking relay
50g Input, Start-repeating relay
50h Output, Start-repeating relay
ALTERNATOR
51 DC voltage at rectifier
51e DC voltage at rectifier with choke coil for daytime driving
TRAILER SIGNALS
52 Signals from trailer to towing vehicle, general
WIPER MOTOR
53 Wiper motor, input (+)
53a Wiper (+), self-parking switch-off
53b Wiper (shunt winding)
53c Electric windshield-washer pump
53e Wiper (brake winding)
53i Wiper motor with permanent magnet and third brush (for higher
speed)
TRAILER SIGNAL
54 For lamp combinations and trailer plug connections
TRAILER STOP LAMP
54g Pneumatic valve for additional retarding brake,
electromagnetically actuated
LIGHTING
55 Fog lamps
56 Headlamp
56a High beam, high-beam indicator lamp
56b Low beam
56d Headlamp-flasher contact
57 Side-marker lamp: motorcycles, mopeds.
Abroad also cars, trucks, etc.
57a Parking lamp
57L Parking lamp, left
57R Parking lamp, right
58 Side-marker lamps, tail lamps, license-plate lamps and
instrument-panel lamps
58b Tail-lamp changeover for single-axle tractors
58c Trailer plug-and-receptacle assembly for single-conductor
tail-lamp cable with fuse in trailer
58d Variable-intensity instrument-panel lamp, tail-lamp and
side-marker lamp
58L Side-marker lamp, left
58R Side-marker lamp, right; license-plate lamp
ALTERNATOR (magneto, generator)
59 AC voltage, output
Rectifier, input
59a Charging armature, output
59b Tail-lamp armature, output
59c Stop-lamp armature, output
61 Alternator charge-indicator lamp
TONE-SEQUENCE CONTROL DEVICE
71 Input
71a Output to horns 1 & 2, low
71b Output to horns 1 & 2, high
72 Alarm switch (rotating beacon)
INTERIOR
75 Radio, cigarette lighter
76 Speaker
77 Door-valve control
SWITCHES
----------(Break-contact and changeover switches)----------------------
81 Input
81a 1st output, break side
81b 2nd output, break side
----------(Make-contact switches)--------------------------------------
82 Input
82a 1st output
82b 2nd output
82z 1st input
82y 2nd input
----------(Multiple-position switches)---------------------------------
83 Input
83a Output, position 1
83b Output, position 2
83L Output, left-hand position
83R Output, right-hand position
CURRENT RELAY
84 Input, actuator and relay contact
84a Output, actuator
84b Output, relay contact
SWITCHING RELAY
85 Output, actuator (end of winding to ground or negative)
86 Start of winding
86a Start of winding or 1st winding
86b Winding tap or 2nd winding
----------(relay contact for break and changeover contacts)------------
87 Input
87a 1st output (break side)
87b 2nd output
87c 3rd output
87z 1st input
87y 2nd input
87x 3rd input
----------(Relay contact for make contact)-----------------------------
88 Input
----------(Relay contact for make and changeover contacts (make side))-
88a 1st output
88b 2nd output
88c 3rd output
88z 1st input
88y 2nd input
88x 3rd input
ALTERNATOR and VOLTAGE REGULATOR
GENERATOR and GENERATOR REGULATOR
B+ Battery positive
B- Battery negative
D+ Dynamo postive
D- Dynamo negative
DF Dynamo field
DF1 Dynamo field 1
DF2 Dynamo field 2
----------(Alternator with separate rectifier)--------------------------
J Excitation winding positive
K Excitation winding negative
Mp Center point terminal
U,V,W Alternator terminals
DIRECTION INDICATOR (turn-signal flasher)
C First indicator lamp
C0 Main terminal connection for separate indicator circuits
actuated by the turn-signal switch
C2 Second indicator lamp
C3 Third indicator lamp (e.g., when towing two trailers)
L Turn-signal lamps, left
R Turn-signal lamps, right
Old 04-10-2009, 13:51
Cross-reference for old and new terminal designations in accordance with
DIN 72 552.
Only terminal designations whose significance has altered are given.
OLD NEW
1 1, 53(wiper), 53e
2 2, 53e
3 53, 53b(wiper)
4 4, 53a, 53b(wiper)
15 15, 49(turn-signal flasher)
15+ 49
15/54 15, 49, 54
16 15a, 15
30 30, 33(motor)
30/51 30, 87, 88(relay)
30f 45
30h 45, 45a
30h I 45a
30h II 45b
30L 33L (motors)
30R 33R (motors)
31 31, 31c, 32(motors)
31a 31a, 31c
31B- B-
50 50, 50b, 50f, 50h
50a 50, 50a, 50e, 50g
50b 50d
50k 50d
50 II 50c
51 51, 59, B+
51 - 59
51a 59
51B+ B+
54 54, 53a, 54g
54/15 15
54d 53(wiper)
54e 33b, 53b(wiper)
54L 49a
58 58, 58L, 58R
58b 58b, 58d
59 59a
85d 31b(alarm switch)
B+30 B+
B+51 B+
D+/61 D+
D-/61 D-
H 71
HL L (L54b)
HR R (R54b)
K C
K0 C0
K1 C, C2
K2 C2
K3 C2, C3
K4 C2, C3
L54 L (L54)
N 55
P C, 57a
PL 57L
PR 57R
R R, 75
R54 R, (R54)
R54b Rb
S 49a, 53(wiper)
S4 49a
SBL (L54)
SBR (R54)
VL L
VR R
+ 15, 49(turn-signal flasher)
53, 53a(wiper)
+2 53a
+15 49
- 1 (ignition coil), 31
and, while i'm at it, here's some interesting stuff:
Power consumption of vehicle electrical leads (average values)
Backup lamps 25W
Battery ignition 20W
Blower motor 80W
Cigarette lighter 100W
Fog lights 35W each
Fog warning lamp 35W
(red fog light on rear)
Glow plugs 100W each
Headlamps, low beam 55W each
Headlamps, high beam 60W each
Heated rear window 120W
Horns and fanfare horns 25W...40W each
Instrument-panel lamps 2W each
Interior lamp 5W
License-plate lamp 10W
Parking lamp 3W...5W
Radio 10W...15W
Side-marker lamps 4W each
Starting motor for truck 2.2kW...12kW
Starting motor for car 0.8kW...3kW
Stop lamps 18W each
Tail lamps 5W each
Turn-signal lamps 21W each
Vehicle heater 20W...60W
Windshield wiper 90W
Old 04-10-2009, 13:52
Old 04-10-2009, 13:55
KLEMAANDUIDING VOLGENS DIN 72552.
Het in de normalisatie voor het electrische vastgelegde systeem van klemaan-
duidingen moet zoveel mogelijk een foutloos aansluiten van de leidingen aan
de apparaten vooral bij reparaties en vervangingsinbouw mogelijk maken.
De klemaanduidingen zijn niet tegelijkertijd leidingsaanduidingen omdat aan
beide einden van een leiding apparaten met verschillende klemaanduiding
kunnen zijn aangesloten. De klemaanduidingen behoeven dientengevolge niet
bij de leidingen aangebracht te worden. Naast de vermelde klemaanduidingen
kunnen ook aanduidingen volgens DIN-VDE namen bij electrische machines
gebruikt worden.
++++++++++++++++++++++++++++++klem betekenis++++++++++++++++++++++++++++++++
1 bobine verdeler laagspanning
4 bobine onderbreker hoogspanning
15 geschakelde plus achter batterij
15a uitgang van de voorschakelweerstand naar de bobine en startmotor
gloeistartschakelaar
17 starten
19 voorgloeien
30 ingang van de plus van de batterij, direct
batterij-omschakelrelais 12/24 volt
30a ingang van batterij 2 plus
31 terugvoerleiding naar batterij min of massa, direct
31b terugvoerleiding aan batterij min of massa via schakelaar of relais,
(geschakelde min)
31a terugvoerleiding aan batterij 2 min.
31b terugvoerleiding aan batterij 1 min. startmotor.
startmotor
45 gescheiden startrelais, uitgang.
startmotor ingang (hoofdstroom)
paralelbedrijf 2 startmotoren startrelais voor opkomstroom
45a uitgang startmotor 1
ingang startmotor 1 en 2
45b uitgang startmotor 2
knipperlichtrelais
49 ingang
49a uitgang
49b uitgang 2e knipperrelais
49c uitgang 3e knipperrelais
startmotor
50 startmotorbesturing (direct)
50a batterij-omschakelrelais, uitgang voor startmotorbesturing
50b startmotorbesturing, paralelbedrijf van 2 startmotoren met volgbesturing
startrelais voor volgbesturing van het opkomrelais bij parallelbedijf
van 2 startmotoren.
50c ingang aan startrelais voor startmotor 1
50d ingang aan startrelais voor startmotor 2
startsperrelais
50c ingang
50f uitgang
startherhaalrelais
50g ingang
50h uitgang
wisselstroomgenerator
51 gelijkspanning van de gelijkrichter
61 generatorcontrole
75 radio, sigarettenaansteker
76 luidspreker
schakelaar verbreekcontact en wisselschakelaar
81 ingang
81a 1e uitgang, verbreekcontactkant
81b 2e uitgang, verbreekcontactkant
maakcontactschakelaar
82 ingang
82a 1e uitgang
82b 2e uitgang
82z 1e uitgang
82y 2e uitgang meerstanden-schakelaar
83 ingang
83a uitgang stand 1
83b uitgang stand 2
83L uitgang stand links
83r uitgang stand rechts
stroomrelais
84 ingang aansturing en relaiscontact
84a uitgang aansturing
84b uitgang relaiscontact
schakelrelais
85 uitgang aansturing (wikkelingseinde min of massa)
ingang aansturing
86 wikkelingsbegin
86a wikkelingbegin of 1e wikkeling
86b wikkelingsaftakking of 2e wikkeling
relaiscontact bij verbreekcontact of wisselschakelaars
87 ingang
87a 1e uitgang (verbreekcontactkant)
87b 2e uitgang
87c 3e uitgang
87z 1e uitgang
87y 2e uitgang
87x 3e uitgang
relaiscontact bij verbreekcontactschakelaar
88 ingang
relaiscontact bij maakcontact- en wisselschakelaar (maakcontact-kant)
88a 1e uitgang
88b 2e uitgang
88c 3e uitgang
relaiscontact bij maakcontactschakelaar
88z 1e ingang
88y 2e ingang
88x 3e ingang
generator en generatorregelaar
b+ accu plus
b- accu min
d+ generator plus
d- generator min
df generator veld
*************************************EINDE******** *************************
