Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 18-01-2009, 10:43
sidecarphil's Avatar
sidecarphil sidecarphil is offline
Send a message via MSN to sidecarphil
Default MK2 VR6 help
hi there all
i'm after some advice on doing a VR6 conversion to my 1989 MK2 GTi
i have heard that if the car is after 1990 then the wiring just plugs in ??
but mine is before 1990 , so what do i need to change ?
is it possable ??
gonna go yo the uk and buy a complete MK3VR6 strip all that i want and scrap the rest
Old 18-01-2009, 11:36
also i will be adding the dashboard to my MK2
Old 18-01-2009, 17:01
Bertus_01's Avatar
Bertus_01 Bertus_01 is offline
Send a message via MSN to Bertus_01
If you will add the mkIII vr6 dashboard in your MkII, then you won't need to change you're wiring.. just put the whole MKIII wiring in you're mkII...
>>> Audi A4 Cabrio <<<
>>> Golf IV Cabrio <<<
>>> Golf II 1.3 NZ <<<
Old 18-01-2009, 18:08
cool that's what i wanted to hear
i want to use the MK3 stearing column because it is adjustable , with the hazard light switch on the column too
does any one know what type of job fitting a MK3 dash to a MK2 is ??
just bolt in or is it a lot of fabrication and cutting ??
Old 19-01-2009, 09:43
GerardMkIIVR6's Avatar
A lot off fabrication believe me
Built NOT Fucking Bought
Old 19-01-2009, 19:58
have you done it ??
i want some thing a little differant
but possable
Old 19-01-2009, 20:38
It is possible and can be done but it's a lot of work especially the windscreen blower part.
Yeah ive don it 10 years ago
And now i'm driving with a MKIV dash(2years now)
Old 19-01-2009, 21:30
cool i want some thing quite easy but good looking
are you in holland ???
i may need some advice LOL
Old 19-01-2009, 22:34
Dashes are not easy(only corrado dashes are)
And yes im from Holland.
Old 20-01-2009, 18:25
ok cool are corrado dashes a straight swap ??
Old 20-01-2009, 18:59
Yeah almost.
Old 20-01-2009, 19:47
Yeah almost.
ok cool i guess i will need the wiring loom , steering column and switchs
will the fusebox work too ??
have you fitted a VR6 to an early MK2 ??
Old 20-01-2009, 20:11
No i fitted everything from a VR6 into a later model.
Early model is more work.
Wat kind off dash do you want now a corrado or MKIII dash?
Old 20-01-2009, 20:33
corrado
thinking of just buying a complete corrado VR6
swapping every thing i need and selling the rest
Old 20-01-2009, 20:41
Okay
Old 20-01-2009, 20:46
so i want a LHD corrado
ANY ONE ??
crashed , smashed or whole
cheep cheep
Old 23-01-2009, 17:55
still want a corrado VR6
Please
Old 24-01-2009, 12:34
DubDoctor DubDoctor is offline
I have a 24v vr6 engine, gearbox, loom ect from a 4 motion, unfortunately the dash is RHD and I'm in the UK
Old 24-01-2009, 16:37
oooh
but cos my car is an early one i will struggle to do the wiring
easier for me
Thanks any way
P.S how much do you want for it ??
Old 24-01-2009, 20:18
Don't worry about the wiring it pretty much plugs together, just the front and rear lights to do.
good luck anyway, worth a try!
£1350 for the 24v only done 12000 miles
P.S. I have converted a Mk1 golf to run a 12v Vr6 in the past.
An early pic during build
