Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk1
Old 24-07-2007, 18:23
silentdub silentdub is offline
Default Drip Rail Delete
Has anyone shaved off the drip rails on an MKI?
Mine have some rusted spots and one area that is weak, I was thinking of cutting them off.
Any pics, or pics of work in progress?
Old 24-07-2007, 18:50
as in raingutters? on the roof? saw it on a caddy, a while back.. looked good.
Old 24-07-2007, 19:17
PerL's Avatar
PerL PerL is offline
That is exactly what he means, Tjaap.
I have never done it myself, but if you want to do it, you need to only cut away sections of it first, and have these sections welded. If you simply cut it all off, you will be able to lift the entire roof off of the car. This can also jeopardize the rigidity of the car, and the result may not turn out all straight.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 25-07-2007, 18:10
And that is also what I was thinking. I have rust on the gutter, After looking at it, I have some rust in the seams.
I can fix anything, but I am not fond of the rail to begin with, so I would hate to fix something that I don't even like, so I am thinking that I will cut, weld, grind and fill over.
This is a part that I never raped before, so I wanted to get some input.
Old 25-07-2007, 19:23
sjampoo's Avatar
sjampoo sjampoo is offline
it'll look awful on a 2 door: no gutter above the sidewindows looks.. well... awful
On a caddy it can be done.. find yourself some pictures of 2-door's w/o gutters, and you probably change your mind
Geld moet rollen*
Old 27-07-2007, 14:16
That is what I am trying to do is find pics so I know what it is going to look like before I do it.
I was also thinking of just removing the rear part of the rails above the rear window.
Old 04-08-2007, 14:06
i'm afraid that'd just be akward
Old 19-10-2007, 20:41
oldskewl's Avatar
oldskewl oldskewl is offline
Send a message via AIM to oldskewl
Seen someone try and ruin their car completely. As far as I know, you can't, the car's held together under there.
"Old enough to know better, but young enough to not give a fuck"
Check out www.liquidr1ck.com
Old 05-11-2007, 18:57
Well, I did it. The driver side drip rail is long gone.
I had to build up the A-Pillar in order make it line up with the door, but it looks good.
The roof is rolled in it, but if you cut small sections at a time, weld them shut, you are good.
I'll be getting some pics soon
Old 05-11-2007, 21:06
PerL's Avatar
Please do!
Old 06-11-2007, 00:13
can't wait.. i really thought that this was another "can it be done? " thread that would never be put into actions..
Old 18-01-2008, 09:45
here's a mk2...
Old 18-01-2008, 09:53
martiepartie's Avatar
shoot me, but i think it's nice! It really smoothens the car, gives it a more golf3 like look.
It doesn't bother me that the rain gutter has disappeared above the rear part of the car.
Don't know if it looks the same on a golf mk1 though.
v40 d4 r-design 2014
Volvo 244 gl 1978
Volvo 780 Bertone 1987
Mini 1275 1977
Mini 1000 1987
Old 18-01-2008, 09:55
Is don't like an mk2 which looks like an mk3.
However i like the shaved away raingutters
Old 18-01-2008, 09:58
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
That DOES look nice, wow... Talk about shaved & smooth
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 18-01-2008, 20:08
PerL's Avatar
Huh?
Old 18-01-2008, 20:26
it's doesn't look waterproof though... or is it just missing the doorrubber?
then again, i don't think it'll be seeing much rain..
