Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk3
Old 30-04-2020, 12:19
pilecarls8 pilecarls8 is offline
Default Mk3 golf water issue
I have an old 1996 golf that has a leak somewhere and only when it rains. But this is the strange thing:
When the car is leaning back, no damp appears in the car. When the car is leaning forward water appears in the foot well of both driver and passenger. Its not coming from the roof as the ceiling inside is dry and the seats are damp free. The outside plastic thing at the bottom of the windscreen is broken (sorry I don't know its proper name) as well.
Which seals should I check first or could it be that plastic bit? If you need any further info please let me know.
Thanks
Old 30-04-2020, 15:16
VeeDubber's Avatar
Volksforum Crew - S2 Racer
- Check the area underneath the plastic to see if there is standing water
- In case you have a somewhat sweet smell in the car, check the heating system for coolant leakages
- In case you have a sunroof, check if the hose running down from the roof through the A-pillar are not cluttered
Old 30-04-2020, 20:17
ar1g3's Avatar
ar1g3 ar1g3 is offline
Most probably the drains for the area that is coverd by the plastic tray are blocked and water pools up and enters the car this way.
'01 Passat B5.5 1.9TDI PD
'95 Passat b4 1.9 TD (RIP)
Old 11-08-2020, 09:45
crendor crendor is offline
Check the door membrane also.
