Old 06-03-2019, 14:17
Jake Jake is offline
Default Audi tt 8N AJQ Db riem — welke dbkit kiezen
Ik zou de db riem en waterpomp willen vervangen van de tt met motorcode AJQ
Modeljaar 2000 eerste inschrijving 2001 maar ik weet niet welke db kit ik moet kopen. Het zou om onderstaande kits gaan. Wie kan me advies geven want ik kan nergens het echte bouwjaar terug vinden van de wagen.
Skf VKMC 01936 SKF of de Skf VKMC 01936 SKF
Old 06-03-2019, 15:12
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Het 10e cijfer in je chassisnummer geeft het bouwjaar aan. Zie de volgende snippet van wikipedia;
Model year encoding[edit]
One consistent element of the VIS is the 10th digit, which is required worldwide to encode the model year of the vehicle. Besides the three letters that are not allowed in the VIN itself (I, O and Q), the letters U and Z and the digit 0 are not used for the model year code. The year code is the model year for the vehicle.
The year 1980 was encoded by some manufacturers, especially General Motors and Chrysler, as "A" (since the 17-digit VIN was not mandatory until 1981, and the "A" or zero was in the manufacturer's pre-1981 placement in the VIN), yet Ford and AMC still used a zero for 1980. Subsequent years increment through the allowed letters, so that "Y" represents the year 2000. 2001 to 2009 are encoded as the digits 1 to 9, and subsequent years are encoded as "A", "B", "C", etc.
Code Year Code Year Code Year Code Year Code Year Code Year
A = 1980 L = 1990 Y = 2000 A = 2010 L = 2020 Y = 2030
B = 1981 M = 1991 1 = 2001 B = 2011 M = 2021 1 = 2031
C = 1982 N = 1992 2 = 2002 C = 2012 N = 2022 2 = 2032
D = 1983 P = 1993 3 = 2003 D = 2013 P = 2023 3 = 2033
E = 1984 R = 1994 4 = 2004 E = 2014 R = 2024 4 = 2034
F = 1985 S = 1995 5 = 2005 F = 2015 S = 2025 5 = 2035
G = 1986 T = 1996 6 = 2006 G = 2016 T = 2026 6 = 2036
H = 1987 V = 1997 7 = 2007 H = 2017 V = 2027 7 = 2037
J = 1988 W = 1998 8 = 2008 J = 2018 W = 2028 8 = 2038
K = 1989 X = 1999 9 = 2009 K = 2019 X = 2029 9 = 2039
Als je dus een modeljaar 2000 hebt zoals je zegt (Letter Y), zou je volgens de SKF website 1 van de volgende 2 sets moeten hebben:
VKMC 01935 (Chassisnummer tot 8N-Y-095000)
VKMA 01935 (Chassisnummer tot 8N-Y-095000)
Verschil tussen deze twee is dat de VKMC een waterpomp mee in de kit heeft. Dit is aan te bevelen om deze mee te vervangen.
Heb je een modeljaar 2001 dan zijn het dus de
VKMC 1936 (Chassisnummer vanaf 8N-Y-095001)
VKMA 1936 (Chassisnummer vanaf 8N-Y-095001)
Verschil tussen VKMC en VKMA uiteraard gelijk. Er is ook nog een VKMA 1136, maar dit is de set zonder waterpomp en zonder spanner. Dit zou ik zeker niet aanraden. Spanner en waterpomp altijd vervangen bij dis-wissel.
Old 06-03-2019, 15:25
Johan1982MK1's Avatar
idd wat hierboven genoemd wordt klopt.
ik heb evt. nog wel een nieuwe spanrol en geleiderol liggen voor een 180pk motor, overgehouden ivm motorombouw in golf 1 voor een klant.
Dan moet je alleen nog een WP en een riem regelen.
als je interesse hebt doe je maar een PB.
Dan kan ik je evt. foto's sturen hoe het eruit ziet.
Út Fryslân
Old 06-03-2019, 15:49
De laatste 6 cijfers van men chassisnummer zijn 026101. Dus dan zou ik de vkmc 01935 moeten hebben.
Zie echter het verschil niet met de vkmc01936.
Bij de autostock zeiden ze dat de 1935 niet van toepassing was, vandaar mijn twijfel.
@Johan bedankt voor het aanbod maar kan deze setjes aan een goeie prijs krijgen compleet.
Old 06-03-2019, 19:30
Geen probleem hoor
Ik gooi het anders in de kliko, vandaar.
Út Fryslân
Old 06-03-2019, 20:22
VeeDubber's Avatar
Wat precies het verschil is, zie ik zo ook niet. Maar er zal een wijziging zijn geweest vanaf dat chassisnummer. Ik zou persoonlijk op de website info van SKF icm je chassisnummer af gaan. Daarmee heb je zekerheid. En anders bel je de autoshop met de vraag waarom zij de 35 voorstellen.
