Go Back   Volksforum.com > International > Off Topic > Computers and electronics
Old 30-11-2013, 16:00
scherm scherm is offline
Default Sony VGP-BPS13A/S battery replacement doubts
Hi all
I have a two year old Sony VGP-BPS13A/S laptop. For the past couple of months, the battery has begun to seriously deteriorate in performance... If the laptop is switched off with full power, by the time I boot, only 5 minutes is now available before it turns off...
Hence, I am looking at replacing the battery. The following are my doubts
1. The laptop was purchased in the US. Will there be any difficulty getting replacement battery here?*
2. Should I contact Dell or will local stores have replacements?
3. Will it be possible to go for 9 cell batteries for improved battery life?
4. Can power surges affect battery life? Is it necessary to connect the power through a surge protector?
5. More often than not I use the laptop when connected to power, but regularly I need to work without power. Hence, I cant remove the battery as recommended by many. Is it better to have the power always on or regularly discharge the batteries?
6. I am thinking of getting a cooling pad to improve battery heat dissipation. I want one that is cheap (less than 1000 preferably) and effective. Please suggest brand and model along with approximate cost.
Thanks in advance
Arun
