Go Back   Volksforum.com > International > Watercooled technical forums > General
Old 15-12-2009, 03:36
archebald23 archebald23 is offline
Default drive shaft flex joint
In reading my manual, it says you must off center position the forward flex disc (trans end). In other words the bolts do NOT center on the holes in the disc. Is there a reason for this? Its a pain changing my drive shaft flex joint.
