Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 20-10-2005, 09:33
g60pops g60pops is offline
Default Digifiz users
Anyone fitted a Digifiz to their golf? If so what parts are needed?
Also are there 2 types of wiring loom, one for early cars and one for later ones?
cheers
Old 20-10-2005, 11:04
Housey's Avatar
Housey Housey is offline
Send a message via MSN to Housey
well.. first of all. you need the wiring loom for the digifiz.. and then you need sensors, like speedsensor etc.. and digifiz is expensive.. and they are known to fail. and stop working properly..
Old 20-10-2005, 12:41
do you know if there are 2 type of wiring loom, one for pre 1989 cars and one for post 1989 cars?
Old 20-10-2005, 15:24
berendd's Avatar
berendd berendd is offline
there are two types..
this man is an expert on digifizz and wiring:
http://www.xs4all.nl/~valo/
unfortunately the site is dutch, but there is an email button.
Old 20-10-2005, 21:29
thanks, i have emailed him
Old 21-10-2005, 06:40
vwjopie's Avatar
vwjopie vwjopie is offline
im having a digifiz also in my MK1 only i've placed the motor, and the all the wires from the same car in mine...
be sure that you have the controle panel for the clock it's important when you want to reset your clock...
it's in the place where the parking brake light is in your dash...
T1 panel 1964
Sold Golf 1 LS 1.8 DX 1981
Old 21-10-2005, 09:05
mouragio mouragio is offline
Send a message via MSN to mouragio
if you haven't got the control panel`for the clock it isnt that much of a deal... you can als use the wires as control... when you put the wires from the clock to a - (minus) the hours/minites will change...
ok; it isn't the most handsome solution, but it works.
Founder of Golfc@brio.Com
Golf cabriolet MK1 2.0 16v ABF
Golf cabriolet MK3 Colour Concept
Kever 1302LS Cabriolet
Peugeot 508SW BLE full options
Suzuki GSX 600F
Old 21-10-2005, 09:56
i already have the control panel for the clock. I only need the wiring because i have the digifiz wiring with central electric (the old type) and i need the new type because my car is a 1991 golf g60.
