Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 10-04-2005, 19:16
mr.Jenssen mr.Jenssen is offline
Default Calling all with knowledge of DIGIFIZ
I just swapped in a 16v from an Edition One, and got the complete wiring harness and a digifiz with it. Thing is, I had the digifiz up and running, but all of a sudden the digits went away! The backlighting and warning lights all work, it's just the speedo, clock, tankgauge and odometer that's dead.
Does this mean I've fried it, or is there some way to fix it? Please help!
Here's my car:
Old 10-04-2005, 23:12
sorry, no answer, but... nice car
Old 10-04-2005, 23:54
PerL's Avatar
PerL PerL is offline
Volksforum Crew - Moderator International Forums
Send a message via MSN to PerL
Sounds like a connector on the rear side has come loose.
If you have a 5 cylinder, you don't need a stereo.
1999 Audi A6 quattro
1990 Volkswagen Golf CL Syncro
1987 Audi Coupe quattro
Old 11-04-2005, 06:15
I'm afraid that's not it, I've checked everything there...
Old 11-04-2005, 06:37
johangolf1's Avatar
johangolf1 johangolf1 is offline
Send a message via MSN to johangolf1
i have got a digifiz dash too...
and i replaced it with a spare one i had in store...
but when i placed the spare one and turning on the ignition it siad insp. (inspection)
and i only have the lower spec everthing above that does not work :s
the original digifiz is in belgium for reseting i hope when i place that one back everything works again...
i hope someone knows this problem then i also can make mine spare digifiz...
btw nice car and i like the wheels...
Golf 1 ls 1.8 8v GTI 1975
Polo 1.0 Classic C 1984
Old 11-04-2005, 16:21
Thanks!
Well, I spoke to the local VAG-dealer here, and they figured that it was dead and gone. But I can't figure out why! There has to be something funny somewhere. I've been so trouble-ridden with this 16v-swap, everything goes pear-shaped. First off I fried the starter for some reason I don't know, then it took me 4 days to get the fuel-pumps running, and now the digifiz. I wish someone had real deep knowledge into it.
Old 12-04-2005, 07:18
Housey's Avatar
Housey Housey is offline
Send a message via MSN to Housey
well, since digifiz isn't all that common, you will have a hard time finding someone who really knows how it works!..
anyhow.. have you checked the instrument? are there any burned capasitors?
and are you sure that all the wiring are correct? and the fuse is new?
Old 13-04-2005, 13:28
Well, everything worked until I changed the relay for the fuel pumps and used the wrong one.
i've had the digifiz apart but could not find anything burned, but there are quite a few microchips in it, so I guess maybe some of them are fried.
Got hold of another digifiz yesterday, so hopefully it will be alright!
Old 13-04-2005, 14:04
Housey's Avatar
digifiz er sykt dyrt!
Old 20-10-2005, 09:36
g60pops g60pops is offline
did you manage to get it working?
Old 20-10-2005, 11:07
Housey's Avatar
i think he did.. after a few new displays..
Old 25-10-2005, 09:01
pikzibner's Avatar
pikzibner pikzibner is offline
Send a message via ICQ to pikzibner
Nice car man
