Go Back   Volksforum.com > International > Aircooled technical forums > Type 1 (beetle '49->)
  #141
Old 12-06-2008, 18:58
DrLaban's Avatar
DrLaban DrLaban is offline
I didn't make it to Bug Run (with the car). Got some problems before paint with the last layer with filler
Today the new parts for the air ride arrived 30 kilos of pure fun
Drag blocks! Heavy duty style for use @ mini trucks
Suicidedoors thought that I was going to use this parts on a mini truck...
5 gallon tank and 2 x Viair 380 Chrome..!
The tank was WAY bigger than the old one. I didn't think it would fit, but hell yeah! FIts like gloooove
Old 12-06-2008, 19:06
Originally Posted by DrLaban
FIts like a gloooove
Old 20-06-2008, 23:01
DrLaban's Avatar
Finally. Installed the new tank and compressors tonight. Working like a charm!
Much better response from the system and I am able to raise/drop 4-5 times before the compressors starts. Earlier I was just able to do this 1.5 time.
Allroad edition
Ass up - nose down
All slammed
Old 20-06-2008, 23:06
levis's Avatar
levis levis is offline
damn!! that shit is wack!! nice job. looking forward to see the car when it's finished
Old 21-06-2008, 09:47
onemirrorman onemirrorman is offline
Superb! This car is going to be a awesome ride.
Keep up the good work (and posting).
** Stock and slammed **
** Ferdinand's freund **
Old 19-08-2008, 19:37
i expect this to be finished by now
Old 04-09-2008, 16:55
DrLaban's Avatar
Just wanted you to know... I am back in action
After a long break I finally got time to continue the project.
I ordered new lower tires and white walls yesterday. That will give me additionaly 30mm of drop in front and rear. Think that will be pretty awsome.
I got a guy working on a CUSTOM front suspension for the bug, including a dual bag setup.
It will be a new customized version of his racing suspension..
Untill then I am going to do some tiny modifications to my ball joint. Today the suspension is on the ground, so I need to make some "room" for the extra drop from the new tires.
Thinking about shaving off these parts and weld it.
Old 04-09-2008, 19:06
Beetlefreak's Avatar
This front-end suspension is so freakin´ nice
Read an article about it in the Ultra VW, it's so much better then the usual frontbeams.
Add dropped spindles to it and your bug is a shovel
Old 04-09-2008, 19:18
DrLaban's Avatar
It's not the same suspension as in Ultra VW, I saw that too. But the concept is the same.
He's designing a new version for me as we speaks. The new is going to be narrowed and got dual bags.
Old 06-09-2008, 14:19
DrLaban's Avatar
Hey guys!
A little update regarding the new suspension.
As we speaks the design of my new front suspension is almost done.
This will be a dual bag (and possible a center mounted shock) suspension with awsome travel
I want to achive two things with a new suspension.
- Awsome suspension travel which will make it possible to REALLY lay "frame"!
- Improved handling/steering.
So, køstom suspension here we come The A-arms are made in aluminium.
Got the "almost ready" drawings from the designer today. It seems like the suspension is going into production soon.
If everything goes by the book it is possible that the suspension is installed late october
Old 07-09-2008, 08:32
DrLaban's Avatar
It seems like the dual shock is the final solution. The last mounts for the a-arms are ready.
The only things that are missing now is the mounts for the shocks (they are now in position) and the mounts for the bags.
The guy who's designing it are missing some info regarding the bags so he can create a functioning air bag in the CAD program.
This for is for testing everything BEFORE he starts the production of the beam for my car. He probably will get the data he needs
from the manufactor of the bag real soon.
Old 07-09-2008, 22:39
DrLaban's Avatar
Gettin' there
Normal mode:
From the side in "slammed" position:
I will be able to "lay frame" with 22" wheels with this suspension, no worries with my 15" wheels then
Old 07-09-2008, 23:19
wow...
Old 07-09-2008, 23:32
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
That's just crazy!!! nice setup!
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 09-09-2008, 15:02
Marcski's Avatar
Marcski Marcski is offline
nice upgrade! should steer alot better too!
Old 12-09-2008, 16:17
DrLaban's Avatar
Got these rendrings today from the guy designing my new front suspension.
The wheels are 17" so imagine what it will be like with my 15's with 165/50 rubber
Slammed 17":
"Offroad edition" 330mm ground clearence with 17s:
I also ordered some upgrade parts for the 'ride yesterday.
Digital display and sensor for all corners and tank:
9 button switchbox for controlling the 'ride:
8 x 3/8" Fast valves
I also ordered new 3/8" air lines.
And my new front and rear tires arrived from Germany
Front tires:
The tires AND wheels are going to be modified before I install them
Old 13-09-2008, 10:27
klenne's Avatar
klenne klenne is offline
this is f*cking crazy
Old 13-09-2008, 11:54
RubenD's Avatar
RubenD RubenD is offline
I see that you are using Rod-ends on both sides of your front A-arms. Why is that?
(for buying them: http://www.rallydesign.co.uk/index.php?cPath=1113)
With the current setup you can align a lot, but it now is also quite easily to mis align everything and create a negative result if we look at the handling of your bug.
Where will the steering rack be mounted? That is also really important for the handling bit, if is is mounted in the wrong position you can get a lot of "bump steer".
I really like what you want to realize, I only would like the know if your designer also thought about that stuff.
Old 13-09-2008, 15:57
DrLaban's Avatar
He has everything under control. Also those parts you mention.
He's working on the steering now, and it seems like it will not be much bumpsteer.
Old 19-09-2008, 23:27
DrLaban's Avatar
A little update.
100 Ft^ of FatMat is on its way from the states. Silence!!!
Yesterday I finally got a pair of original PopOuts =) Also in good condition.
And tonight I got my new _W deck lid_
Modified by DrLaban at 12:02 AM 9-20-2008
