Go Back   Volksforum.com > International > Technical > Aircooled projects
  #121
Old 07-03-2016, 09:15
knarfmk1's Avatar
knarfmk1 knarfmk1 is offline
Originally Posted by Ben Modified
Thank You!
A few photos with the good camera
Great pic and a very nice project!
Old 07-03-2016, 12:40
Love the rear with those fat tires!
Old 09-03-2016, 02:12
Ben Modified's Avatar
Ben Modified Ben Modified is offline
While building this truck, I wanted to make sure that I could park it inside my security fence and close the gate
Thats got to be at least a 1/4" to spare!
Also got some work done on the drivers side
http://www.BenModified.com
Old 17-03-2016, 00:42
Finished the drivers side cab corner and under cab area
Started smoothing off the hundreds of tack welds on the headlight filler panels.
Old 02-04-2016, 19:35
Progress. Welded up the cut in the door and removed the alignment clamps
Also made some progress on the drivers side bed side and engine vents. Welded in the mounting strips and grafted in the vents but still have lots of tack welds and grinding to go.
Old 14-04-2016, 22:15
Finished up the front turn signals
Old 15-04-2016, 08:32
hahaha that is really awesome!
Old 16-04-2016, 00:08
Thanks!
I am not completely happy with the engine venting so I am trying something that looks a bit more aggressive. I split a piece of 3" exhaust tubing and starting building a scoop for each side. The front section will be permanently mounted and the rear section will be mounted with dzus fasteners for access.
The flat panels are butt welded in...took forever
Old 16-04-2016, 08:39
DenJenMel DenJenMel is offline
The turnlights Are they even legal?
Daily: '91 Golf MkII 1.8 8v
Former VW's: '88 Golf MkII 1.3, '88 Golf MkII 1.8 GTI, '89 Golf MkII G60, '00 Golf MkIV 1.8, '99 Lupo 1,4, '03 Lupo 1.4, '99 Polo 6N2 1.4 16v, '00 Polo 6N2 1.9 SDI
Old 16-04-2016, 11:54
They sure are!
Old 21-04-2016, 22:31
Part 12 of the Build on YouTube
https://www.youtube.com/watch?v=a_a4wMibd6c
Old 25-04-2016, 00:16
Old 25-04-2016, 07:37
Great workmanship on the scoop, but not sure about the look.
Old 25-04-2016, 08:20
knarfmk1's Avatar
I like it, it flows well with al the other curves
Old 25-04-2016, 13:07
Nice upgrade, put some nice flames on the side
Old 28-04-2016, 00:36
Got started on the Engine Cover/Hood today. The plan is to make it look very similar to the roof on the cab
Old 28-04-2016, 09:44
looks already really good, the bending you did is amazing! What did you use to get the nice curves in the metal, a steel pipe?
Old 28-04-2016, 10:35
Thanks! The rough curves in the center section were made with a piece of 3" exhaust tubing. The rear section was shaped with a round plastic hammer and sand bag and then run thru an english wheel to make the compound curve. Once the rear section is completely welded in I will use the english wheel on the center section to smooth the rough bends and tighten up the large expanse by giving it the same slight egg shape that the roof has for strength.
Welded up most of the rear section but still need to fill the corners, weld the underside and smooth
Old 29-04-2016, 23:43
NICE!, i wasn't expecting an enginecover at all
Old 30-04-2016, 03:09
Thanks, its coming along!
