Go Back   Volksforum.com > International > Technical > Watercooled projects
  #101
Old 05-04-2011, 22:32
2fast4you's Avatar
2fast4you 2fast4you is offline
Today I finished modifying the tunnel to receive the Golf MK5 selector mechanism .
Started by cutting a bigger hole for the selector mechanism and drilling holes to get it fixed:
the small holes were made to remove the MK2 selector mechanism mounts
did some modifications on the tunnel to fit the MK5 selector mechanism
and here is how it came out:
TUNINGGARAGE
REVO TECHNIK
Old 14-04-2011, 21:20
2fast4you's Avatar
Some progress was done these past days.
I totally redone the sub frame for the Golf MK5 dash. I newer posted pictures of the sub frame and the work done for it to be fitted because I didn't like how it was done :thumbdown:
So I started everything over again and here is how everything was done:
first of all I bought a new subframe
and the original Golf 5 holders that the sub frame is tighten to and cut them to fit
then more cutting
and then started making some pieces to weld on the chassis that would except the holders for the sub frame
after I welded the holders I cut the rest of the sub frame to fit between the pieces
took the sub frame to be welded and here are the results:
and...
after the sub frame was fitted next was the intake for the air conditioning
first I took a part of the air conditioning to be a little modified
and then everything could be welded
After all of these I had to redo the shifter because it had to move 2 sm back ( it was too close to the dash)
TUNINGGARAGE
REVO TECHNIK
Old 14-04-2011, 22:23
wow, nice work!
Old 14-04-2011, 22:32
knarfmk1's Avatar
knarfmk1 knarfmk1 is offline
neat! the subframe looks as if it was originally there!
Old 17-04-2011, 18:35
2fast4you's Avatar
I'm almost finished with the roll cage and now planing on making a support to the suspension housing from the roll cage
Here are some pictures from the roll cage:
And here is the support to the suspension housing from the roll cage that I planed on doing
What do you think?
TUNINGGARAGE
REVO TECHNIK
Old 21-04-2011, 00:22
bprijs's Avatar
bprijs bprijs is offline
This is very nice to see, keep on going the good work
Mijn 74er slapend project
Oud 75er swallowtail project
Pm me voor meer info
Old 22-04-2011, 13:09
2fast4you's Avatar
Here are some pictures of what I have finished yesterday :
TUNINGGARAGE
REVO TECHNIK
Old 27-04-2011, 06:02
DÁ-BRT's Avatar
DÁ-BRT DÁ-BRT is offline
My compliments it looks great again! Also the support for the rollcage to the suspension housing looks good, this will compensate for the bends in the cage.
Groetjes,
Bert
VW Jetta 1.6 1984 (NL)
Audi Q7 3.0 TFSI 2019 (UAE)
Audi TT 2006 (UAE)
Old 27-04-2011, 06:23
shouldn't the support go all the way to the housing though? welding it to the raintray won't do much imho.. the raintray is such flimsy material.
Old 27-04-2011, 09:46
2fast4you's Avatar
It will be going all the way to the housing but from the pictures you cant see
There is a place where the raintray and the housing come together and there I plan to weld the support
TUNINGGARAGE
REVO TECHNIK
Old 16-05-2011, 14:27
2fast4you's Avatar
Some updates
I finished the rear reinforcement
also finished the front reinforcement from the suspension housing to the roll cage
in the mean time I mange to find time to build this :
so I can move the shell in mu garage :laugh:
and some shopping was done:
Rear 4 piston calipers from Shevrolet Camaro SS 2010+ for the rear axle
brake disc for the rear :
also bought H&R FRONT SWAY BAR VW GOLF 3 VR6 25MM
and the emblems:
TUNINGGARAGE
REVO TECHNIK
Old 16-05-2011, 15:20
Very nice!
Old 16-05-2011, 16:01
Luukhedriks10 Luukhedriks10 is offline
When do you think your car is ready to ride?
Old 16-05-2011, 19:32
VeeDubber's Avatar
Volksforum Crew - S2 Racer
What diameter are those brakes, they look massive on the pictures!
Old 16-05-2011, 19:52
2fast4you's Avatar
A hope that next year I'll be riding it. I'm geting ready to take the car to painting and after that...will see???
TUNINGGARAGE
REVO TECHNIK
Old 16-05-2011, 19:54
2fast4you's Avatar
I think the calipers ride on 355mm disc
and the disc that I plan to use are 310mm
TUNINGGARAGE
REVO TECHNIK
Old 27-05-2011, 20:34
tuner4vag's Avatar
tuner4vag tuner4vag is offline
Smile
Originally Posted by 2fast4you
And this is how the Haldex 2 is going to look
why did you cut out the floor panel ??? was it in the way of the haldex or you needed more space for the custom subframe part ???
very nice . looking fwd for updates
Old 27-05-2011, 21:57
2fast4you's Avatar
No it doesn't come in the way of the Haldex or the custom subframe part I just needed more space to work and in that space I plan on putting a special battery holder box that comes from a Golf R32 MK5.
TUNINGGARAGE
REVO TECHNIK
Old 29-05-2011, 21:24
2fast4you's Avatar
Finally finished the roll cage
also sorted out the pedals
and the most important thing for me, the gearbox mount
still some minor things to be done and then... off to the paint shop :P
TUNINGGARAGE
REVO TECHNIK
Old 29-05-2011, 22:04
DÁ-BRT's Avatar
Looks good, like the way you did with the engine / gearbox supports. Have you thought about the lower gearbox stabilizer?
I'm very curious about the result after painting.
Groetjes,
Bert
Audi TT 2006 (UAE)
