Go Back   Volksforum.com > International > Watercooled technical forums > Polo MK 1,2 and 3
  #81
Old 12-05-2008, 22:51
sjampoo's Avatar
sjampoo sjampoo is offline
And that's on a cam-phone..
Just got back from a wonderfull, warm day @ RetroMania,.. AND got past the 1000 km 'running' in. It's now ready to be 'tuned', and used. Did have some temp. problems though: Can't run it at 100km/h for a long time, or oil temp raises to 130+ 0C. So in need of an oil-cooler. Thinking of an EGT aswell, since I do just love how smooth it runs (exept for idle).
Very nice to just have the feel of that pile of torque left as reserve under my rightfoot, and knowing it will only be getting more out of it.
And btw: stunning to see that the number of hits on 'G40 + Diesel' on google suddenly raising...
http://forums.tdiclub.com/showthread.php?p=2137043
http://forums.vwvortex.com/zerothread?id=3829579
http://www.vwdiesel.net/phpBB/viewt...ht=supercharger
http://en.wikipedia.org/wiki/Volkswagen_Polo_Mk_II
Wonder what mileage is in it to.
Geld moet rollen*
*maar dan liefst wel m*jn kant op!
Old 13-05-2008, 19:31
PerL's Avatar
PerL PerL is offline
Any idea how many hp it has? You should do a test with a G-Tech.
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 15-05-2008, 10:36
sjampoo's Avatar
Since I've been 'running-in' the G-charger, I only recently started to put the pedal to the metal..
I really haven't got a clue yet, and the 'feel' is so different from any (non)-turbo-petrol/diesel car, I've driven, so I can't really tell what it compares with.
Stating this doesn't mean it's a really unique feel; I just don't know what it feels like since I haven't driven that many different (powerfull) cars
I did stick to the boot of a 1.3 liter (petrol) polo on motorcycle carbs, where the owner (Serge) thinks it should produce about 70-75 BHP... The Audi A4 20v 1.8 (Marcel86c) behind us couldn't keep up..
2 major things need to be solved though:
- Oil temp is going up at any speed above 100 km/h. It stays in the 'okay' area ( 110 degrees C) as long as I don't go over 100 km/h (for more than about 2 minutes).
It goes over 120 / 130 degrees as soon as I keep it above 105 km/h for longer
then 2 minutes. Have got a big oilcooler, which I will setup in front of the radiator. Brackets have to be made though, and a termostat/tubing is missing to.
- fuel: it's still on the very lean side. Will have to modify the fuelpump, but I've been calculating what pouly I can use to: running a 75mm stock pouly on the charger now, but when fitting a 65mm (don't panic) pouly, it will run just as fast as a stock-petrol G-40; A diesel engine will only do 5500 rpm max, where the petrol version goes up to a whopping 6300 rpm (to 6500 rpm) until the revlimiter kicks in.
It's now doing 0.5 bar at idle, 0.6(to 0.7) at about 2000+ rpm. When I fit a pouly to spin it at normal speeds, it might even go up abit... Not dramatically I guess ( I read somewhere a G40 will only produce about 1 bar as a absolute max. ) Anyway: there will only be a bigger airflow surplus... and I didn't even modify the fuelpump far enough to compensate for the switch from atmos to charged.
Minor things I did fix:
- horn
- pressure gauge
- 100% Veggiepower
Minor things I'm working on:
- budget for a VDO EGT gauge
- centre console to house all dials.
Geld moet rollen*
Old 15-05-2008, 10:43
RubenD's Avatar
RubenD RubenD is offline
Then you might have a look at this website for your gauge: http://www.egauges.com/eg_typeI.asp...er=All&Manf=VDO
And I suppose that the filterhousing of a DX engine wont fit on your smallblock engine? That housing does have a built in themostat.
Old 15-05-2008, 11:02
PerL's Avatar
Oiltemps in the 130º range shouldn't really be a problem, as long as the coolant is at a steady 85-90º. The Audis I own/owned (my present A6, my Coupe, and the '92 Cabrio I owned earlier) that had original oil temp gauges have all had the red marking in the 170-180º range.
Are oil/water heat exchangers available for the 801 engines? I know many 827 engines have these, it might be worthwile to install one in addition to the oil radiator.
Old 15-05-2008, 11:14
sjampoo's Avatar
nah, i've got the oil/water heat exchanger,.. but I use it in a differnt way to soup up the temp from the veggiefuel
Since I've only got room for a 1.0 radiator, I'm not fond of the idea having the oil warmup my coolant even more. Which reminds me: Get water temp gauge fixed. I still got the dash of the petrol engine in it, which has a different scale/reading then a diesel gauge. So no real clue what the water temp is about, only that it's steady a 100 km/h, and up a bit at 110+km/h ( so yes: watertemp goes up abit with rising oiltemp).
Thanx on that egauses link; any experience on ordering? Since they are in the US, and VDO is german,, I suppose it should normally be cheaper to order from germany directly.. or do they just sell the VDO gauge with there own sender unit?
Geld moet rollen*
Old 15-05-2008, 11:34
PerL's Avatar
Since there is more water than oil in the engine, and the water is thermostatically controlled, the water will keep the oil cooler, not the other way 'round. The only thing is that the fan may be running more often than now.
Old 15-05-2008, 16:42
RubenD's Avatar
I have looked on the internet for an oilpressure sender. In the Netherlands/Germany it would sat me back like 50-60 euro. In the states somewhere around 25-30 euro.
And as you can see here: http://www.volksforum.com/albums/fi...ll_original.jpg
It's an original VDO part.
I don't know why, but they are a lot cheaper then what I have found anywhere within Europe.
The downside, obviously, is the import tax. Arne bought 3 gauge and the needed sender @ egauges.com http://www.volksforum.com/forum/sho...9&postcount=189
I didn't have a good experience with them. I orderd my pressure sender, that had to look up the costs for the USPS shipment. But they just didn't replied after that. I still don't know what went wrong. The nevertheless where really quick when Arne bought some gauges.
Old 15-05-2008, 17:52
sjampoo's Avatar
hmm,. sound good,. I've got the Vision Black Series, and the looks satisfy me
From Sandtler / DutchPowerTrading.nl
Anlage zur Überprüfung
der Abgastemperatur incl.
Geber.
Ø 52 mm
12 V, Meßbereich
100°C-900°C,
Best.-Nr. 397 015 003 C
€ 288,-
egauges sets me back a little less:
0-1600F 2 1/16 °Fx10 $99.50
Part No: 310-953 Notes: 12' Kit. (Exhaust Temperature), includes gauge (310-951), sender (323-892) and wiring harness
I just only noticed they aren't really advertising with the metric-gauges ( Fahrenheit? WTF?! ),. so I'll check out what payments the accept (paypal?) and if they can deliver gauges in metric.
Thanx for your help/tip sofar!
Geld moet rollen*
Old 13-06-2008, 00:04
Gallagher's Avatar
Gallagher Gallagher is offline
congratulations my friend
- golf mk2 16vT
- polo -76 projekt
- derby -77 old skool
Old 11-07-2008, 23:46
serge pot's Avatar
kopbewerking ,pm
Old 13-07-2008, 20:55
sjampoo's Avatar
Mind you:
1) outside temperature
2) dieselpump not modified in any way
3) G-charger pully still stock, so on a diesel engine (lower max-revolutions) it's de-tuned compared to OEM petrol
4) I'm quite/very satisfied..
Geld moet rollen*
Old 11-08-2008, 01:29
Gallagher's Avatar
pump up the pressure now
- golf mk2 16vT
- polo -76 projekt
Old 25-11-2008, 11:51
Kentuky Kentuky is offline
Hello, I got a polo MK2 2f, 1.4Diesel and I have also a G-LADER, liked the project, I am thinking about doing the same, but liked a few more picts!
Thank you. Greetings from Portugal
Old 07-02-2009, 10:23
sjampoo's Avatar
Project 'closed' for now.
Will hopefully start and complete a stripdown, recolour, rebuild from 06-03-2009 to 06-03-2010...
Geld moet rollen*
Old 04-03-2009, 10:06
DÁ-BRT's Avatar
DÁ-BRT DÁ-BRT is offline
I saw that the project is on hold. But if you are stripping for rebuilding it I will offer you my support on upgrading the ve-pump.
I like the project and the fact that you finished makes it even better!
Groetjes,
Bert
VW Jetta 1.6 1984 (NL)
Audi Q7 3.0 TFSI 2019 (UAE)
Audi TT 2006 (UAE)
Old 10-03-2009, 20:17
sjampoo's Avatar
Strip for FULL rebuild.
So, yes: If you would like to.. please, be my guest.. I'm still unsure about what and how to ' tune ' the engine, since I would like it to be on a dyno, but most companies don't bother with either Diesel or anything without a chip to be modded.. Some claim to be capable, but they are way to expensive..
I know you don't have a dyno, but you do have lost o experience.. If you dare to take the challenge, I will be grateful!! I hope there's some more horsies in there, but I would definitely like more torque!!
Geld moet rollen*
Old 24-04-2009, 09:57
sjampoo's Avatar
teaser
More nudity in the (near?) future!
Geld moet rollen*
Old 24-04-2009, 10:28
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
Wow, that is a stripdown...you weren't kidding
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 04-06-2009, 18:42
Cool, I see you're from Oosterbeek, That's the one near Arnhem right?
If that's true we are practicly neighbours, I'm from Schaarsbergen.
love the project of a diesel g-40
I want change mine to diesel too, but not a g-40, I wan't to fit a 1.2 litre tdi 3 cilinder.
