Go Back   Volksforum.com > International > Technical > Aircooled projects
  #81
Old 16-12-2015, 01:57
Ben Modified's Avatar
Ben Modified Ben Modified is offline
Finished up the inner fenders
Working on completing the front sides of the fenders
Cutting up and using another trailer fender
Used the planishing hammer to round off the cut edge to match the rest of the fender
Going to use some metal mesh to make some compartments in the corners of the bed which will be covered by the bed sides.
http://www.BenModified.com
Old 16-12-2015, 14:08
Wow nice work on that fender, that is some oldskool metal work
Old 17-12-2015, 01:32
Thanks! Here is todays progress.
Engine compartment venting to the Bed
Pocket in corner of the bed for venting and hauling greasy items or just things that I don't want sliding around, chain etc.
This will be hidden by the Bed Sides
Old 22-12-2015, 01:15
The passenger side is done!
Pocket behind the right rear wheel
Welded on some Dzus fasteners for a removable cover over the charcoal canister behind the left rear wheel.
Took the measurements for an Aluminum Treadplate bed floor. Going to the big city soon to pick it up. They have a huge shear so I can get the size I want and nice smooth lines.
http://www.facebook.com/BenModified
Old 23-12-2015, 11:28
Audilimburg's Avatar
Seriously impressive.
It's a great thread to read through and the craftmanship is amazing.
Can't wait to see the endproduct on the road
Golf 1 1977 in the making
Old 24-12-2015, 03:46
Thanks! Got it running today, trying to post the video now but will likely take hours to load. 1080p
Old 24-12-2015, 12:26
It's Running!
Part 10
Old 31-12-2015, 02:27
Sprayed the frame rails under the bed floor with some aerosol bed liner. Also drilled and tapped all the bed floor mounting points and bought some nylon washers to place between the bed floor and frame rails to allow air floor and prevent moisture accumulation.
1/4" Aluminum Bed Floor
Started playing around with an idea for the headlights. I made up a reversible locking spring loaded headlight mount to secure some polished bullet headlights. When rotated back, they resemble the dagmar bumperettes.
And started making up the under the cab lower rails.
Benmodified.com
Old 03-01-2016, 13:03
Finally get to Drive It! Wow, so much fun!
Test Drive Video
Old 03-01-2016, 15:35
Long testdrive
Nice work !!
Old 03-01-2016, 15:57
Was that a cop car during the testdrive?
Old 04-01-2016, 00:44
Originally Posted by Sjeesbeest
Long testdrive
Nice work !!
Thanks! I will post more after I get the through the break in period!
Old 04-01-2016, 00:47
Yes, but I am legal even without the glass as long as I am wearing eye protection. Seat belts are not required as the VW did not have them from the factory.
Old 04-01-2016, 00:50
Started on a cage for the cab today. When finished, it will have 3 sets of 3 point seat belts!
Old 09-01-2016, 01:42
The cage is done and the seat belts are in.
Old 10-01-2016, 01:03
Installed the Safari Windshields today.
Fabricated a couple of outboard mounts and welded to the roll cage. Much stronger than stock.
Old 10-01-2016, 03:39
Looks very nice !
Old 10-01-2016, 18:45
Wow nice progress, the welding looks very good. The sound is nice are you mounting any other pipes to boost the noise
Old 11-01-2016, 01:23
No, the noise is already sufficiently boosted! The camera just doesn't do a good job of recording it.
Old 11-01-2016, 01:24
I finally got around to re-covering the seat frame for the truck. Got tired of riding around on a piece of cardboard! I went ahead and installed seat heaters while I was at it.
