Go Back   Volksforum.com > International > Technical > Watercooled projects
  #61
Old 21-10-2013, 09:15
Volkdent's Avatar
Volkdent Volkdent is offline
Slow, tedious progress, but progress nevertheless.
Built the template for the side storage pods, the drivers side will house the rear relay block.
To close off the frame rails, I built a plug that also includes a nut to affix a bracket for the trailer hitch. I see myself building a trailer that I can haul track tires with and that is also a tent someday.
The inner fender seam between the Boxter and the bug is almost complete. Built a panel that merges the strut mount to body.
Jason
If I could just get paid for my sleepless nights....
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Oval Ragster-'57 Rag/'04 Boxster S
Old 07-11-2013, 02:42
Volkdent's Avatar
Little update:
Got these aluminum mufflers, yes, I said aluminum. Got a buddy that builds big HP cars and he swears by them, very, very light, no cracks yet for him. I'm doubtful, but they aren't that expensive and I could flange them to a stainless system if I wanted and still get big weight savings.
Ditto for cheap Chinese headers. They are supposed to be stainless, and they are except for the severely warped flange. Had to spend a bunch of time on them to get the flange flat and to open the bolt holes up. Really surprising how simple some of the mistakes are, but equally surprising how little a complete header setup was.
Working on the fitment to the fenders, these will have to be widened ever so slightly unless I like the smell of burnt rubber around every corner. Looks kinda cool though...
Finally got the condenser attached to the rad, used aluminum spacers my wife uses for her business, re-threaded them for metric, and had Eric at NorCal Motorsportz weld them on for me.
A before shot of the area I need to fill between the Boxster chassis and the tubing.
The mess I have yet to tackle...
Jason
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 07-11-2013, 11:04
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Still going strong
Very impressive!
I'm very suprised that the wheelbase is almost the same, reffering to one of your first shots with the beetle body hanging over the porsche.
Passat B1 LS
Passat B8 Businessline R
Old 07-11-2013, 11:19
smeerpeer's Avatar
OMFG...what a cool project!
VW Golf 3 Cabrio 2.0i
VW Passat 1.6i Trendline
VW Golf 2 1.6i CL -> Exit
VW Passat 35i 1.8i CL -> Exit
Cordoba 1.4i 16v Vario ->Exit
Cordoba TDI Vario Signo ->Exit
VW Golf 3 TDI CL Variant-> Exit
VW Vento TDI GL Highline -> Exit
Old 07-11-2013, 12:02
Matheo's Avatar
Matheo Matheo is offline
Great project!
'06 A4 1.8T Quattro
'85 Transporter
'85 Golf
Old 19-11-2013, 12:47
SjorsMK2 SjorsMK2 is offline
waiting for an update on this awesome project,
Je moet niet dronken dat ik denken ben.
VW Golf MK2 1.8 RP 1989.
Old 21-11-2013, 07:25
Volkdent's Avatar
The details continue - gauge cluster now.
Cut the stock speedo ring and moved it over 1.5". It was really tricky because I couldn't put the cluster in level, didn't flow with the curves, and it couldn't flow with the curve because it would look too tilted, I ended up with a compromise between the two.
Jason
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 21-11-2013, 07:42
Volkdent's Avatar
Front and rear latches will be controlled by stock solenoids. Deepest part of front latch aluminum will be embedded in fiberglass to bond it to inner hood surface.
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 21-11-2013, 08:01
Love the cluster!
Old 22-11-2013, 14:50
SDBNL's Avatar
SDBNL SDBNL is offline
MAN! That is awesome..! Keep u the work. Amazing..!
Old 09-12-2013, 12:26
Jonne Feith's Avatar
Jonne Feith Jonne Feith is offline
How's the progress on this awesome project?
Old 05-02-2014, 07:05
Volkdent's Avatar
Stopped at least for another month, bought a new house and need to build a new shop, I'll post again when momentum returns!
Jason
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 03-03-2014, 19:40
Spijky's Avatar
Spijky Spijky is offline
Great project!!
Looking forward to see some more pictures.
Dirigent van een geföhnd 4 cil. orkest
Golf MKII GTI G60 5drs
Oma's Edition One 16V
__________________________________________
Golf GTI 8V MKI Waiting for Restauration
Volvo V70 classic 2.5T Daily
Old 30-04-2014, 13:57
Any updates yet? Pics of the new shop are welcome too
Old 06-07-2014, 20:58
Volkdent's Avatar
Dirt is still being moved on our hillside, should have a flat spot to build a 26'x40' shop next week. 0 progress on this project, of course things take more time than you expect to get rolling.
Here's a shot of a Super/Boxster S from Sweden, hope to be doing this in my bug next year.
https://vimeo.com/m/99021642
Jason
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 30-10-2014, 23:57
Updates !
Old 27-02-2015, 07:32
Volkdent's Avatar
Nothing new to report, she just sitting there. A roller, yes, but no progress. May be done with engineering next week on the garage structure, but don't expect to be working on it again for at least a couple of months.
Jason
1960 VW Bug UBRDUB
Walkaround
1st Drag Run /
Dyno Run
Old 06-12-2015, 08:10
I read on germanlook your pics are dead because of hosting them on Facebook.
Did you know you can host them on here too!
