Go Back   Volksforum.com > International > General > Who is who
  #301
Old 18-09-2009, 18:55
rabfan rabfan is offline
Originally Posted by Chromosexual
(paint) new carbs that i have almost already destroyed.
come on RJ!
Stufffing the carbs with blue cheese is not a break in procedure Paul. Keep the carbs from ingesting cheese and they should be fine.
Old 18-09-2009, 22:01
Chromosexual's Avatar
Chromosexual Chromosexual is offline
fuck this shit
no new friends
Old 19-09-2009, 01:42
well i didnt get my carbs tuned tonight............fuel all over the place... plugs were wet Tom..........
finally got my H&R ultra ultra lows on - here she sits with a bit of windage to go... I am also happy to say that after 20+ sets of wheels and hours of researching I got my stance SPOT ON. You will have to wait for those pics
no new friends
Old 19-09-2009, 02:45
82dumptruck 82dumptruck is offline
screw pics, i wanna see that stance at h2o
Old 19-09-2009, 03:36
Big Caddy's Avatar
Big Caddy Big Caddy is offline
Float level is two pages back.
79 golf gti wannabe.
Old 19-09-2009, 09:11
" Float level, in mm, typically refers to the distance from the face of the carburetor top cover to the float. With the top cover held vertically (float pivot at the top) and the float tab (Lc) resting against, but not depressing the spring loaded ball in the needle valve, measure between the face of the carburetor top cover to the top or bottom of the float. On carburetor models where it is required to remove the float to replace the top cover gasket, the measurement should be made with the gasket in place to the gasket face."
why does this sound like fucking eskimo?? if the float level is resting against, but not depressing the spring loaded ball in the needle valve, why do you need to measure?? ok Paul shutup and stop overthinking this.........
...then I see the little side note at the bottom of the diagram and get more confused....
brass float only?
specs may vary?
Plastic float height 12.5mm to tip of float?
OK I know I have plastic floats...........I DONT HAVE BRASS. Is this just another example of me chasing my tail & getting NOWHERE at the end? I THINK SO
WTF!
no new friends
Old 19-09-2009, 09:32
As I felt that maybe these diagrams were a little cryptic, I decided to look elsewhere for more info..........and it got more confusing!!! same carb.............diff float height..... WTF?!?!
no new friends
Old 19-09-2009, 15:07
Big Caddy's Avatar
sorry mang, but what don't you understand? just set it to like 12.5ish
when the float raises in the carb it will hit the ball on the valve. measure the distance. when the valve is depressed by the rising float, measure the distance. if the first of the two is off, bend the tab slightly to set it correctly.
easypeasylemonsqueezy.
Old 19-09-2009, 16:50
Big Caddy's Avatar
Make yours look like this.
Old 19-09-2009, 17:27
no new friends
Old 20-09-2009, 00:37
and sir..............you will be seeing her
no new friends
Old 20-09-2009, 02:43
great to hear man!!!!!!!!!!!
Old 20-09-2009, 03:46
yeah i redid the cams (again)
the biggest bitch today was the syncing of the carbs
the floats (BTW) were a bit off........
the idle screw linkage setup was a little diff that the other setup I had so I really had to crank down that idle screw to get it where I could sync them.
I feel bad that I turned down Ariel (owner of Perfect Metal Finishing) to get together tomorrow to detail the fuuuukk out of the 78 but she is running so poorly (took her for a spin a few mins ago - lean all out) that I didnt feel comfortable with him polishing my turd the way it was.
Hopefully things will go better tomorrow...and I cant actually focus on aesthetics like I always do.......pfft
no new friends
Old 20-09-2009, 20:22
ahhhhhhhhhhh so fucking sweet
still a bit lean ..... but OMG I got her up to 4th gear and WOW!!!
now i gotta clean her up .................. WAAAAH
no new friends
Old 20-09-2009, 21:35
Big Caddy's Avatar
now get cleaning biznitch. drop the anal ease.
Old 20-09-2009, 22:01
Ariel is coming along with me
I might just Quilmes myself :o
no new friends
Old 20-09-2009, 22:41
sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
you showing?
Old 20-09-2009, 23:10
Big Caddy's Avatar
If you are showing I hope you registered. Registration ended 2 days ago.
Glad to hear Ariel is coming along. He can give me a business card or 10 for his chrome work.
Old 20-09-2009, 23:48
Should I bring stuff for chroming?
Old 21-09-2009, 00:18
you showing?
oh si
your call senior......
I hope you registered. Glad to hear Ariel is coming along. He can give me a business card or 100000 for his chrome work.
fixed ...and yes I registered a few days back....maybe last tuesday or so
no new friends
