Go Back   Volksforum.com > International > Technical > Watercooled projects
  #261
Old 04-04-2013, 22:32
EnVeeZee's Avatar
EnVeeZee EnVeeZee is offline
Quattro Donor - NvZes10vG60
Audi A4 Avant S Edition '20
Audi A3 Sportback '14
Old 07-04-2013, 04:38
Audi1981's Avatar
Audi1981 Audi1981 is offline
5 Cylinder Turbo Donateur
Nice work!
Gotta love those wheels!
"Surfin' down the avalanche!"
VW Lupo 1.4 16V BSO racer
Old 09-04-2013, 21:48
2fast4you's Avatar
2fast4you 2fast4you is offline
Today Arrived:
and off to do some work *
Got the car on wheels ...and painted the headlights in black
Bought a clutch thanks to Issam Abed
TUNINGGARAGE
REVO TECHNIK
Old 09-04-2013, 21:56
ewcaddymk1's Avatar
very nice I love it
TSJA ......zeg het maar!!
Old 10-04-2013, 06:02
Edward's Avatar
Edward Edward is offline
THAT bonnet...why didn't VW develop it like that in the first place?
Lovely vehicle!
Old 27-04-2013, 22:03
2fast4you's Avatar
Axle shafts finally finished. After a long search for original ones wit the right dimensions ... i had ro make them :P
but there is one thing that I really don't like
I think the angle is too big and it will be braking joints
as for the others ....
when lowered on the ground they are pretty straight
got it out so it can see some sunlight
and with my other project
made a holder for the expansion tank
finally arrived ... boot carbon cards
TUNINGGARAGE
REVO TECHNIK
Old 29-05-2013, 21:59
2fast4you's Avatar
Well there is some progress
the engine holders have been redone
now the engine is 4sm to the back and 4 sm up towards the hood
advantages of the modification of the holders:
- more space in the front at the radiators
- the shifting cables were a bit short but know all OK
- the drive shaft looks perfectly positioned
- the oil pan is not lower than the front axle and the gearbox is not that close to the axle as it was
and everything in filler and waiting to be painted
made the hood shocks from a passat (but they are a bit short so I will be getting ones from an Audi A5)
it seams they will not get in the way
then everything painted and assembled
than messed a little with the electrics
bought some elbows and pipes f70X1.5mm
BSH catch can
Forge blow off
mounted
and today I did this:
more to come
TUNINGGARAGE
REVO TECHNIK
Old 30-05-2013, 00:34
Wow. Just wow!
Old 31-05-2013, 09:11
2fast4you's Avatar
Yesterday I welded the pipes (mig CO2) but them sanded the welds a bit and polished them. Its not the best job but its OK
and cut out a piece of the front bumper, so I can get more air to the IC
TUNINGGARAGE
REVO TECHNIK
Old 31-05-2013, 09:24
Some info about the other project?
Old 31-05-2013, 11:17
2fast4you's Avatar
Well the other project is an Audi A3 8l which originaly was 1.9 tdi 90hp. Then I made it a 1.9 tdi (150 arl engine) 196hp and then waht it has now, a 3.2 v6 DSG + quattro
Here are some pictures:
now it will be repainted in Arnacio Argos orange
new wheels, discs(front ,rear) brake pads, powerflex bushings for the front and rear axle and everuthing else that is a consumable part
like :
even a new transfer box for the quattro
and bought original Audi S3 8l wings and side spoilers
TUNINGGARAGE
REVO TECHNIK
Old 31-05-2013, 11:33
Edward's Avatar
proper projects !
Old 07-06-2013, 22:44
2fast4you's Avatar
made this for the lower engine mount
The friend who welded this says it will newer snap
TUNINGGARAGE
REVO TECHNIK
Old 16-06-2013, 10:16
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Nice A3!
Old 16-06-2013, 12:44
addyVW addyVW is offline
nice cars
daily mk4 tdi
Mk2 tdi afn 160pk gesloopt
mk4 tdi verkocht
mk2 tdi afn 155pk gesloopt..
polo 6n2 1.4 verkocht..
lassen,AFN,AGR disriem vervangen,groot,klein onderhoud pb maar
Old 16-06-2013, 12:46
2fast4you's Avatar
TNX guys
TUNINGGARAGE
REVO TECHNIK
Old 06-07-2013, 12:43
Black Devil's Avatar
Nice!
Golf 3 VR6 3.0 Compressor
Golf 1 1.3 Carburateurs
Golf Rallye
Dailys:
Phaeton W12 & T5GP California
Old 16-07-2013, 21:54
2fast4you's Avatar
Nothing much happening with the build got some parts gathered
Greddy Profec Boost controller
the return pipe from the IC to the TB is a f63 but i decided to make an F70 one because the exit from the IC is F70, and in the future I plan on getting an F70 TB so...
Siliconhoses parts
I also ordered some parts from Samco that this firm did not produce
and finally the clutch and the 38mm wastegate are here in my hands
and I cant believe the quality difference between Samco (blue) and SiliconHoses (black)
the pipe from the turbo to the IC fixed
and the thing bothering me for so long :banghead:
no room for the wastegate but i put in a smaller brake booster (golf mk5 R32) and now there is a bit more space.
but I still had to redo the manifold:
and welded
and:
also bought parts for the scream pipe
so we'll see what happens
TUNINGGARAGE
REVO TECHNIK
Old 16-07-2013, 22:51
Herm Schreurs's Avatar
Very nice builds here man!
Awesome!
I just have the advise to reinforce the mk2 subframe if you're gonna use the dogbone as in the newer models, i'e seen then tear and break a few times as a lot of torque is pulling the subframe. They are not design for the forward torque to hold.
A very big compliment to you guys!
Old 16-07-2013, 23:44
2fast4you's Avatar
Awesome!
Thanks about your advice I'll have that in mind
TUNINGGARAGE
REVO TECHNIK
